minotto
  • Content Count
    138
Community Reputation
6 Neutral
About minotto
  • Rank
    Journeyman
Personal Information
  • Occupation
    designer
  • Location
    CA, USA
Recent Profile Visitors
  1. It looks like i'm going to have to get used to the keyboard shortcuts again.
  2. I wonder why Logitech changed the compatibility with MacOS and VWs. I was using the M500 corded mouse for years and it worked great with VWs.
  3. I was using the Logitech M500 mouse with VWs for year. The middle button was configured to the fly over tool. Since upgrading to MacOS 11, the button functions don't work in VWs. I upgraded the mouse to M500S and software but i'm still not able to configure the mouse toe VWs controls. Does anyone use a Logitech mouse with MacOS 11?
  4. Matt, I converted the file to 2020 saved in 2019 again and it seems to be fine now. Something happened in the conversion. Thanks, paul
  5. I just upgraded to VWs 2020 from 2019. I opened a document saved in 2019 and converted it over to 2020. One page has partial section details and the markers are missing. Some of the viewports are correct (10a below) while others are wrong, that is not lining up with the annotations. I tried creating a new partial section but keep getting full sections. Is there some new setting i'm missing in 2020?
  6. It turned out to be a visibility issue with the Sills Class. Thanks for everyone's input.
  7. Here is a plan view of a window at the top right (elevation 2' and a sliding glass door at the bottom left (elevation 0). I've set the parameters to be identical as far as jamb, sash etc.... Is there a way to have the door show up like the window? I can't seem to find the right parameter.
  8. Strange, I looked under "Window" but didn't see "palette options". However, clicking the minus sign on the Resource Browser worked. Thanks Kevin and Pat.
  9. I just upgraded to 2018 and migrated my settings from 2017. My original settings allowed me to keep the Resource Browser open, opening it with a shortcut, but now it closes when not clicking within it. I can't find the setting to change this back. Where would it be?
  10. From reading the other posts on the subject, my understanding is that there is no way to remove the green squares that are Constraint marks applied by default on dimensions. The screenshot attached shows one angle dimension with them and one without. But is there a way to change the color to white so they would blend into the background?
  11. I want create a "true" drawn line without any snapping to points or digital "corrections". I tried selecting Smoothing off in the preferences and all the choices in the Snapping Palette are off, but the line comes out jagged. Are there any other settings to adjust for this?
