martinfdc
228 -
Posts posted by martinfdc
That's correct @Amorphous - Julian, that's exactly what I meant.
Many thanks for your answer @markdd
I guess for now I'll solve my problem doing it manually as you say.
yes, that's what I mean
@markdd This is what I'm talking about: http://app-help.vectorworks.net/2019/eng/index.htm#t=VW2019_Guide%2FViewports1%2FSection_Line_Instances.htm&rhhlterm=section line instances&rhsyns= &ux=search
The lines that indicate where a section is running through in a plan view; I can't get to show these on a horizontal section viewport.
Hi,
I'd like to know if it's possible to show instances of sections in horizontal section viewports. I've tried but the VW only shows me viewport which are top/plan and not horizontal section viewports.
Thanks in advance.
Sure @Nikolay Zhelyazkov I'll remind you once VW 2020 comes out.
On 5/28/2019 at 11:13 AM, Nikolay Zhelyazkov said:
I will fill in a bug about that and make sure this is editable as well and not constantly set to 2/8.
Hi @Nikolay Zhelyazkov , sorry for bothering you. The bug with the worksheets keeps on occurring. Do you know when will it be fixed? Have you filed the bug?
Thanks in advance.
With the release of VW 2020 and Mac OS Catalina just around the corner I hope very much that the story of VW 2019 and Mac OS Mojave does not occur again. I hope that VW 2020 and Mac OS Catalina have a friendly relationship from the start. It would be awesome to update directly to Mac OS Catalina when it comes out and not have to delay the update because of Vectorworks! 🙏🙏🙏🙏
- 2
It's a whole different story though if the wall feature is placed at the end of the wall... Wall projections are not meant to be placed at the end of walls, am I right?
I attach a file in which a wall with a wall projection should then pass to a wall that doesn't have brick cladding. Can't find a way to model this.
@Matt Panzer many many thanks for your answer. With this I can solve my problem.
Anyhow I'll post a wishlist item explaining that it would be ideal if the wrapping of the feature component would be done to the height the wrapping component has set.
- 1
Hi,
I attach a wall that has a wall feature attached to it. The wall has two components, one of the components (the brick cladding), has an offset relative to the wall of - 50 cm
I'd like the wrapping of the feature component be done by the brick cladding but at the correct height. Is this possible?
I tag @Alan Woodwell and @Matt Panzer as you both seem to know very well the wall tools. I would appreciate very much a hand!!
- 1
no worries... I finally managed! I just had to flip the order of the components in the wall style.
Does any body else think like me or am I the only one? 😅 I hope many of you also wish to use the space bar (instead of the ctrl key) as a way to temporarily invoke the orbit tool in a 3 button mouse!
Many thanks for your answer @zoomer. It's a real pity one can't change this. It's much more comfortable to reach the space bar (it's larger and more centered on the keyboard) than the ctrl key.
If I wouldn't have a three button mouse and only a two button mouse, I would leave the space bar to pan, but, when you have a three button mouse what I do is that when I pan I don't press the spacebar, I simply press my middle mouse button. So with a three button mouse it makes more sense ergonomically to press the space bar an not the ctrl key to temporarily invoke the orbit tool.
I hope this preference gets implemented somewhere in Vectorworks Preferences in the future! Either in a service pack or in a future release of VW.
Hi all,
When using Vectorworks and a mouse that has a middle mouse button one can hit ctrl + middle mouse button to invoke the ORBIT TOOL. If one simply hits the middle mouse button than one can PAN.
Here's my question. I'd like to hit space bar + the middle mouse button and invoke the ORBIT TOOL. Is there a preference somewhere that one can change in order to do this?
Thanks in advance!
2 hours ago, Matt Panzer said:
@martinfdc, This appears to be fixed in Vectorworks 2019.
You are right @Matt Panzer, the bug has been fixed.
Just now, Matt Panzer said:
Hi @Matt Panzer I was just editing my response to you.
The bug is not present any more.
Use hinge marker class setting was activated but I was doing something that did not make sense in another place. In my section viewport, under advanced section viewport properties>Objects Beyond/Below Cut Plane>Line Style> I was using a class setting and not the original attributes of the window.
My apologies, my bad!
1 hour ago, Matt Panzer said:
@martinfdc, This appears to be fixed in Vectorworks 2019. What version are you seeing this problem in?
@Matt Panzer I'm using the spanish version of Vectorworks 2019 service pack 3.
@Matt Panzer take a look at this post which in a way is related to this post. There's a bug that doesn't show hinge markers according to a class in hidden line.
On 9/20/2017 at 5:05 AM, Christiaan said:
@JHAM Alan's right, unchecking this option will fix your immediate problem.
But I think there's still a bug when using the Class attributes option that causes the line to be solid in Hidden Line render. Rendering in OpenGL using this option is fine, for instance.
The bug of not showing the correct line characteristics using the class attributes in a Hidden Line render still exists. I hope it gets fixed soon.
I think this is a bug. I hope this is fixed in a future service pack.
Hi @jeff prince
I'd go for the iMac instead of the iMac Pro. It's Intel i9 processor is very good and according to what I've been seeing on the internet has been managing thermals very good.
It's a shame though that the new iMac doesn't have a T2 chip or two more thunderbolt ports and the 10Gb ethernet port but all of this stuff are not essential at least for me...
Also never buy RAM from apple if you have the option to upgrade it yourself and buy it elsewhere.
A video comparing both machines:
Here I leave you two screenshots of a beast of a machine under $6000 ($4249.00 + $948.99 = $5,197.99)
https://eshop.macsales.com/cart/?added=OWC2666DR4S128S
Hope all this helps a bit on your decision.
- 1
Multiply two database cell values
in General Discussion
Posted
Hi,
I want to multiply two database values but I can't manage to do it.
I attach a screenshot of the results I get.
