Bengt Nilsson
    23
Reputation
0 Neutral
Personal Information
  • Occupation
    Nanotechnology, retired
  • Hobbies
    Audio technology
  • Location
    Sweden
Recent Profile Visitors
  1. Hi, I need to split a generic solid into two parts or halves, cutting/slicing it by a dividing 2d surface. None of the more obvious VW tools (intersect/section solids) let me do this. How can I do this? BN
  2. I am always double clicking. In fact, dragging works better, thanks for the hint!
  3. Hi all, In VW2022, picking a symbol from the resources grabs it at the leftmost edge, not at the symbol origin (usually center) as it was before (2021 and earlier). Usually I want to place the symbol origin at a certain position in my drawing, so I find this behaviour annoying. I have to simply drop it somewhere, click twice to release it, and then place it again. Is there any way to change this behaviour? BN
  4. If I create an object with a circular hole using subtracted extrudes, create a symbol of it, and present it in a viewport in a sheet layer, I cannot take a radial dimension of the opening. It says "A circle is required". Linear dimensions of a symbol are fine. I find this very inconvenient. Any workarounds?
  5. I need to create a simple rectangular extrude with two sides tilted by 10 degrees. Right now the only way I know how to do this is to create two wedges and then subtract them from the extrude. However, It seems more logical to me to use "chamfer edge", but this is always 45 degrees only. The option "tangent entities" might be useful (?) but I do not understand the explanation. Can someone please suggest a convenient method to do this?
  6. Ok, it seems I need to study worksheets carefully, I have never used it. Could you please share an example of what you did above? it looks like it is exactly what I need.
  7. Thanks, I will try to find out about "Materials" in 2021. I do not intend to specify the material in the title block, this spec should belong to the design object. I could actually manually enter the weight in the title block, if only I could find a way to calculate the weight of the object from volume and density. The volume and weight of object composed of complex solid subtractions is sometimes not so easy to calculate, so a function would be handy if it existed.
  8. Hi all, Is it possible to automatically calculate the weight of an object in Vectorworks, by its volume and density? Either by internal function or external script? Ideally it should be accessible as a parameter in the drawing title block, and be presented as title block data. Often, the total weight of a design is asked for, and it is a pain to do this calculation manually in e.g. excel for all the parts. BN
  9. Hi all, I am making a mechanical design of an object, and I have an instance of it as a 3d symbol in my design layer. When I do a sheet layer with viewports of the different views and do Dimensions in Viewport Annotations, "Radial Dimensions" is not working. If I select a circular object the center of the radial dimension measurement ends up in a galaxy far, far away outside the object. However, if I go back to the design layer and do "Convert to group" and then update the viewport, it works. Is this a known problem? Am I using a stupid design method, trying to maka an annotated drawing of a 3d symbol? The reason want to do it this way is that I am afraid that the 3d symbol which I am sharing between drawings might not be properly updated during the design process, due to my mistakes. If I take the measurements on the actual symbol, I can be relatively sure it is correct. If I use a "flattened" copy of it, they might be different. BN
  10. Hi! I am designing some mechanical machine elements using Vectorworks 2019 for MacOSX. To make a proper drawing for the mechanical workshop, I am requested to use the rendering option "Dashed hidden line" in the sheet viewport. However, I always get a rather poor "sketchy" render, where circles are becoming raggedy polygons instead of a nice circle. The "hidden line" options settings does not affect this at all. When using wireframe, the shape is perfect. Is there any way to correct this, or is there any other rendering option available?
  11. Now upgraded to VW2018, so for me the case is closed. BN
  12. I noticed another peculiar thing, In an old drawing, where I have a Section Viewport in a sheet layer, and do Object Info (it truly says "Section Viewport"), it WILL NOT UPDATE, the striped edge banner does not disappear when I press the "Update" button. In the same sheet layer, I have other standard Viewports of my design, not Section, and they do update normally when requested. I don't remember now which VW version I used to create the drawing.
