DomC
    676
Files posted by DomC
  1. Circular Marionette Stairs
    Three Examples of Marionette PIOs of Circular Stairs.
    925 downloads
       (0 reviews)
    2 comments
    Updated
  2. Reshape Node 2D
    https://youtu.be/vuCvK4OwN80 German Movie
    https://youtu.be/Nm0te1zmpVY English Movie
    Structure of the Input:
    1. Group with Geometry group (send to back) and Reshape Zone definition (send to front). Best practice is to use a blue smbol without screen plane objects
    2. Reshape Zone group has further groups. Every reshape zones (polygons) is grouped with a dimension object. The dimension is the link to the script. The parameter name is a prefix of the dimension text
    3. Use one of the existing examples to understand the system
    Limitations:
    1. Supportes not 3D, Chain Dimension, path objects, rectangles. Container objects are not reshaped but moved (like the reshape tool)
    2. user origin has to be set to vectorworks origin
    3. not mix of screen-plane and layer plane. Use all layer-plane
    4.  ...
    300 downloads
       (0 reviews)
    6 comments
    Updated
  3. Rectangle Packing
    The heart of this Marionette example is the RectPack node. A node with over 2600 lines of code!
    It supports dozens of packing algorithm to pack rectangles on another rectangular area in a space and time-saving way.
    The right combination of packing and bin algo gives the ability to pack rectangles in a way you want to have them on your machines (as close as possible, always cut complete board, less cuts etc.)
    Actually not even myself know, which packing algo ist right for which use case.
    Also for professional use case, usually there is a machine dedicated software, which packs the port in a way which match best for the machine.
    So I see the main use case to pack parts on a board for milling them on a cnc-machine as example for model-making. Workflows which uses a guillotine-workflow (always cut the whole board) often have special requirements which maybe could be reached with the choice of packing algorithm or maybe can not.
    The Marionette Example based on foundational work:
    http://www.secnot.com/   Python code for packing algorithm
    Jukka Jylang - A Thousand Ways to Pack the Bin - A Practical Approach to Two-Dimensional Rectangle Bin Packing (2010)
    Huang, E. Korf - Optimal Rectangle Packing: An Absolute Placement Approach (2013)
    General Features:
    - Input of basic data like length and width
    - Input of additional data
    - object input (node detects if part input are objects and process them like rectangles)
    - sort by material
    - use a list of stock materials
    Not all input combinations works at the moment. Recommended to use the existing examples to get correct input values.
    German Movie
    https://youtu.be/yyZGvazL7Ik
    1,195 downloads
       (1 review)
    51 comments
    Updated
  4. SpacesfromList.vwx
    This Marionette Script creates multiple space objects from worksheet data.
    A very nice and time saving Marionette script to automate a routine peace of work.
    Please consider, that the the script takes the area column and calculate the square with that. If you have a language settings with comma instead of points for decimal seperator, the calculation will fail. Use points as decimal character or eliminate decimal places in your list
    1,017 downloads
       (2 reviews)
    31 comments
    Updated
  5. Beautiful Marionette QR Codes
    This node is the end of boring QR codes that anyone can make.
    With this node, the creative designer creates their own QR codes. There are endless design possibilities.
    But be careful: at some point, the QR code may no longer be readable by your smartphone.
    How it works:
    Enter the text (e.g., URL link) in the info palette, press Enter > done.
    Have fun with it!
    How it works:
    Have fun with it!
    43 downloads
       (0 reviews)
    0 comments
    Updated
  6. People Crowd 1.0
    This is an older but still fantastic marionette. The thing which is a little newer is the version of the poeple Crowd polygon which i never shared i think. With the following Features:
    1. One big Focus Point where people crowding (Entrance, Food Track etc.)
    2. Smaller Focus Points where people talk together etc.
    3. The Script gets different symbol folders. It collects from a folder symbols in the focus arreas (waiting people, sitting people as Example)
    4. Ant a different Folder for People which moving between the focus points
    To Make your people layout, you could combine more than one PlugIns with different settings. I think you need one PlugIn per Special Focus.  i think this could also be used for trees, cows and other living objects.
    78 downloads
       (0 reviews)
    0 comments
    Submitted
  7. Get and Set Marionette OIP Parameter
    With this two nodes, we are able to set or get the parameter of an Marionette PIO or wrapper.
    Can be used to access the values in the OIP by script or another Marionette.
    The Screenshot shows an example in which every of those pillar is an own marionette PIO (Script as symbol to instance the PIO).
    Note:
    It is not possible to write the parameters via Worksheet. Also it is not possible to read Marionette Object parameters directly into a worksheet. To read Marionette object parameters in a worksheet I recommend to write data into a record format and list those values in a worksheet.
    169 downloads
       (0 reviews)
    2 comments
    Updated
  8. Page Numbering
    This Document contains two Marionette PlugIns.
    Those PlugIns will simplify the workflow where we have more than one page on one sheet layer.
    1. Someone who uses your plans will have an advice if the document of the plan layout are complete.
    2. You can see which page you have to print directly on the layout without counting the pages
    This Marionettes supports Normal- and Landscape Format. Where pages are printed in a different order.
    Note:
    One Marionette (multi label) puts a label on every page and have to be inserted at the center (info-palette x0 y0 > please do not move).
    The other Marionette (single label) can be putted freely on the layout. It returns the page number of its center point.
    The Multi-Label Marionette, do not support uneven pages like 6.2/2.6
    80 downloads
       (0 reviews)
    0 comments
    Updated
  9. Record Popups
    Generally:
    In everyday life job is very often reading and writing record fields of user record formats
    and PlugIn objects.
    Situation Now:
    1. Marionette users have to know the record name and need a lot of knowledge to get the universal name of PIOs
    2. Marionette users needs to manually find and transfer the field names into string nodes and also have to know a
    workflow to find the universal field names of PlugIns.
    3. copy/paste of the names or writing the values is stressful and often results in type errors.
    What does this Nodes improve:
    1. Quick access to record formats, PIO records and field names
    2. See the localized and universal names (if exists) of the fields, returns universal names to the script automatically
    3. Can also be used in combination with "print debug" to show names for editing existing networks without using directly
    the node
    Record Popup.mp4
    103 downloads
       (0 reviews)
    0 comments
    Updated
  10. Apartment Tag / Wohnungsstempel
    About this File
    This tool is available in english ("Apartment Tag") and german ("Wohnungsstempel"). The contents are nearly the same just translated.
    This Marionette Tool summarize all Space-Areas, which are part of the same Appartement Number and shows the result in a symbol based Marionette stamp. Alternatively we can pull out sum of apartment area with a worksheet. But this Marionette is also a nice method to do this.
    Instructions:
    1. The Marionette Objects access to the field "11_Room ID" of the space object. Every other field can be used if necessary by editing script.
    2. With the Marionette PIOs field "ApartmentID" you can tell the stamp, which apartment should be displayed
    3. With the Checkbox "Layer from Apartment Tag". You can make the Tag collecting spaces of the tag's layer. Otherwise it will collect areas from the layer of the layer popup
    4. You can exclude Spaces with specified keywords. Delimiter for Keywords is "$"
    5. To use the Marionette PIO on the Target Document, copy/paste the PIO and then import the Symbol definitions from the Folder "ApartmentStamps" on the Target Document.
    Über diese Datei
    Dieses Werkzeug ist auf Deutsch ("Wohnungsstempel") und auf Englisch ("Apartment Tag") verfügbar. Die Inhalte sind bis auf die übersetzten Bezeichnungen nahezu gleich.
    Der Marionette Wohnungsstempel fasst Wohnungsflächen zusammen und zeigt diese in einem Symbolbasierten Marionette-Stempel an. Raumflächen können auch mittels Tabellen ausgezogen werden. Der Wohungsstempel ist eine komfortable alternative.
    Anleitung:
    1. Räume welche zur gleichen Wohung gehören, werden mit dem Standardfeld "Raum ID" identifiziert. Auch andere Kriterien für die Wohungszugehörigkeit können festgelegt werden, dazu muss das Script geändert werden.
    2. Im Feld "WohnungsID" wird eingestellt, welche Wohung angezeigt werden soll.
    3.  Mit der Checkbox "Ebene von Wohungsstempel" lassen sich explizit die Räume auf die Ebene des Wohungsstempels eingrenzen. Ist die Checkbox deaktiviert, gilt die Einstellung "Räume von Ebene:"
    4. Räume mit bestimmten Namen, können hier ausgeschlossen werden. Trennung der Namen erfolgt mit "$"
    5. Um den Wohnungsstempel auf einem anderen Projekt zu verwenden, zuerst das PlugIn mit copy/paste übertragen, dann die Symbolressourcen im Ordner "Wohnungsstempel" auf das Zieldokument importieren.
    869 downloads
       (2 reviews)
    34 comments
    Updated
  11. Vectorworks to SVGnest direct connection
    This Marionette can be interesting for Laser and cutting jobs. But Mainly it is Study how to use the Vectorworks Web-Dialog to access a Web-Application. The Date is send and reveived over (REST) API. The Exchanged Data is an SVG which is parsed over JSON Formats. Used Engine for Nesting is www.svgnest.com
    for rectangular shapes, use this one:
    This Marionette Network is sending all shapes on a layer (or by custom criteria)
    to a Web-App which contains a SVGnest installation and a custom API for Vectorworks
    1. Draw a BIN on which you want to NEST the other shapes. Place it topleft of the BIN on your Origin
    2. Tested with Layer Scale 1:50, 1:20 mm and BINs of ca. 1-2 meters. It works with all
    Units, sizes and scales but the very first Preview may be very small, cropped or too big.
    3. No Holes in polys are supported directly (you can have but nothing would be placed inside)
    But if you draw a smaller shape inside another it is taken as a hole.
    4. If ready run the Marionette (You will have to cancel by not saving the result or cancel in
    the dialog after the nesting process)
    5. If you have multiple CPU cores it will go much faster. It uses one worker for every core.
    6. Click on your BIN, choose the settings button (twice).
    If you define an offset between the parts reduce the curve-tolerance smaller than one. 0.5
    as Example or lower if you see any issues.
    7. Press START and wait till parts are placed on the BIN. The Process will calculate infinite and
    try to optimize the result till you click STOP.
    8. Press SAVE, wait a sec and then just exit the VW WebBrowser by close or press the Button
    Bottom right to close.
    9. Choose Option to move your original shapes on the BIN(s) or a copy
    Known Limitations:
    - Some shapes are not converted correctly to SVG maybe. Which is not a big accident because the Application do not import some geometry it keep the original geometry.
    - Complex geometry could take (too) long to nest.
    - I take took no control on the nesting process which is processes the NESTING the process
    is powered by https://svgnest.com
    Notes:
    You can also use an alternative way:
    1. Export DXF to inkscape and export SVG
    2. Or directly export SVG by https://forum.vectorworks.net/index.php?/topic/78280-export-to-svg-menu-command/
    (The exported SVG from the Marionette is not directly accessable and also the quality and compatibility is just fitted to that one usecase so quality of the Marionette SVG is maybe low compared to the above professional Export-PlugIn)
    3. Import it to SVGnest.com or use their new project DeepNest
    As I mentioned. Primary a study how connect to an even bigger world out from a Marionette. BTW such a connection can be a task nearly as big as the nesting-part itself.
    85 downloads
       (0 reviews)
    0 comments
    Updated
  12. Marionette Translate Character to Geometry
    A Marionette PlugIn, that collects a custom drawing (font character, picture whatever) and refer it to a regular font character.
    This "Font" is placed into the control geometry container. Also we could just use a blue symbol.
    The Heart of the script is a custom node "create font dict" which manage collecting the control geometry. Also it returns a dictionary sequence data type. A dictionary is very useful if you want to have pairs of data. In this case a character and a drawing group with informations forms a pair.
    Sure, the script could be improved by several things (multi-line, alignment, page based etc. )  But I think it is very useful to have that plug in. Have fun with it. Maybe you can share your own fonts and your wonderful handwriting here. Thanks.
    Usecases:
    1. Handwriting Font
    2. Vectorfont (ability to use sketch view)
    3. For Milling Machines
    4. Fast inserting of object sequences
    5. ...
    Update v2019
    1. Script Crashed if input Geometry was None (Integrated a script blocker and an Alert Dialog )
    2. Input Dict was always None, because use of an outdated Script command (vs.GetType() instead vs.GetTypeN()). Issue in many other scripts. One of the very rare incompatibilites of Script commands the past Years.
    153 downloads
       (1 review)
    0 comments
    Updated
  13. Make Planar Nodes
    Often what is missing to make usable Elements of this geometry is the fact, that
    faces need to be planar to make buildable elements. Also it need to be planar to make
    extrudes and other solids out of it.
    The Two nodes "get Planes" and "ProjectPoints" are a step in this direction.
    This example do nearly the same the existing Surface Array already can do. Except it directly
    gets geometry from a subdivision object.
    Anyway this has to be seen as a first step trying to model hulls with planar AND closed shapes. Which looks like a very hard task.
    43 downloads
       (0 reviews)
    0 comments
    Updated
  14. Create Record from external File
    This example shows, how to create a record format with fields from an external csv or text-tab file with marionette.
    This example maybe needs the following know how which is not automatically is handled by the script:
    1. Save Text with excel, open office or any other application as separated text file or tab separated text file.
    2. Setup the "import txt" node-popup with the needed text encoding. Try utf-8, Latin1,  macLatin_2 or other encoding to handle umlauts or special character issues.
    3. The Exmaple just checks the first line of the text-file and creates record fields from them
    4. The path to the text-input in the attached example is related to the document path. Save first your Vectorworks document. Or use an absolute path input.
    5. No warranty or charge for this script, play first on a new file or on the attached file.
    I whish you success with it
    134 downloads
       (0 reviews)
    0 comments
    Updated
  15. Creating nice color schemes
    This Marionette uses a Web-Dialog to create color schemes. The created colors can be imported as colors and textures directly in Vectorworks.
    Instruction:
    1. Run the Network
    2. configure colors
    3. Don't forget to click "save"
    4. close Web Dialog, the Vectorworks fetches the created colors and creates a preview with rectangles.
    Hint:
    right click > Wrap Marionette Network > right click > convert to menu command
    95 downloads
       (1 review)
    0 comments
    Updated
  16. Label_From_Worksheet.vwx
    More powerful, than a database or text application.
    A Vectorworks integrated label-script-example with Marionette. The attached example shows how to import address data from a worksheet (could be other data and sources) and additionally places  symbol beside the address. The power of Vectorworks and Marionette allows us to put everything you like dynamically on that labels. As example sort by male and female names (if possibly :-) and generate a individual pictures. Just infinite possibilities.
    217 downloads
       (0 reviews)
    0 comments
    Updated
  17. Symbols in Rows
    Places a Marionette object, which contains symbols from a specific symbol folder. Offset and rows, can be defined. Handy for a quick and printable preview of symbols in a specific folder.
    623 downloads
       (3 reviews)
    0 comments
    Updated
  18. creating records from txt or xls
    This Network shows how to create fields from an existing xls or txt file.
    275 downloads
       (0 reviews)
    0 comments
    Updated
  19. Standard Rooms
    This Script it made for users which have an Vectorworks Architecture but have not the core business to draw walls, slabs and roofs to make a presentation ambient for their designs. It helps to create room situations very fast and especially very easy.
    1. Concept
    It pulls Symbols out of a Symbol folder which are Room-Presets. As Presets Rooms can exist, that have a rectangular shape and inner dimension of exact 2 meters. Slabs are supported also (No extrudes etc.) and roofs. Best Practice maybe is to keep existing presets and just change classes as example. If we are working with presets we can "save" a lot of parameters in the Object-Info-Palette which makes it faster and easier to use.
    2. Workflow
    Copy Symbolfolder and PlugIn in your project and you can use it immediately. If you want to change details you can ungroup (cmd/ctrl. U) the objects into Walls and slabs. So you are able to insert Windows, Doors or changing other Details.
    3. Known Limitations/Details
    - Rectangular Room presets only
    - Switch on/off ceiling with classes
    - Texturize by classes
    - Changing classes by editing preset Symbols and attach other classes/attributes
    - You can Mirror the Room to get left/right rooms
    85 downloads
       (0 reviews)
    1 comment
    Submitted
  20. Name Popup
    About This File
    This Node is similar like the Name-Node. Instead of writing the Name in the Node Infos, you can select the Name from a Popup, wich maybe is a little bit more comfortable. Using the Name input is often used by myself for quick testing, debugging or Stand-alone Scripts. This node helps eliminating errors like writing the name on the wrong field or copy/paste the name on wrong place etc.
    A new innovation implemented, is a visual feedback of the node, which zooms the named object while choosing it in the popup. Which is a very interesting advance to improve user friendliness of Marionette nodes.
    Ideas for further improvements:
    1. Checkbox if zoom or not (not sure, because to many checkboxes decreases usability)
    2. A Pick option to pick an object and auto-naming and inputting with this picked object (Not implemented, because I have not got it to work, that a pick callback runs inside of a Marionette script)
    Name Popup.mp4
    59 downloads
       (0 reviews)
    0 comments
    Updated
  21. Worksheet based Popup, push Button
    Generally:
    Popups significantly raises usability of Marionette Scripts. Also for advanced marionette scripters often it is hard to search and enter the values.
    Situation Now:
    1. The Popup values has to be written in an input node or the params class of the node, which do just execute if node is edited.
    2. Popups are not dynamically unless the values are calculated by the script  and then the Popup will popup every time the script is running.
    What does that Node improve:
    1. The popup values can be directly pulled from a worksheet.
    2. The provided node filters one popup with another popup, which is very efficient for fast filtering and combine choices
    Worksheet Popup.mp4
    126 downloads
       (1 review)
    0 comments
    Updated
  22. Import pillow 2022
    Unsure on which different OS and how long this will work. I just need it for myself and wanted to share, because I know some of you are waiting for external-library-fix with OSX. For my usecase the issue at the Moment seems to be fixed. Not tested with Windows or other OSX Versions. Runs on my Machine intel Mac Book with Big Sur and Vectorworks 2022 SP1.
    Do not run on Windows yet.
    Feedback what it does on your machines is very welcome.
    54 downloads
       (0 reviews)
    0 comments
    Updated
  23. Extracting Geometry from PIOs or Symbols
    This Script is made to made separate objects from geometry which is nested in PlugIns or Symbols. Those could be uses for special usecases. The Script is criteria and class based. So it would be necessary the nested geomtry is in a seperate class.
    The Script uses 3 Criterias
    1. (left) The Input PIOs or Symbols by a free criteria
    2. (middle) The class which contains the required objects we want to extract
    3. (right) The Criteria for deleting the "debris" of the scripts. Which is selectable by class of the source PIOs/Symbols and deletes everything which are groups inside of this class (it deletes not the source objects, because those are symbols or PlugIns)
    This is also a possible method to ungroup things. Many ungrouping workflows do not work with Marionette, because the ungroup script command does not create handles to the resulting objects. But the group after ungrouping will be in the same class as the source objects. So using classes could be a workaround to catch the results by a second criteria. Not noble, but it works 🙂
    Use is on your own risk and in a copy of your project (like always)
    This Script is made for troubleshooting special requirements by resorting geometry for IFC Export.
    113 downloads
       (0 reviews)
    0 comments
    Updated
  24. Wall Component Volumes for Custom pSet
    If NetVolume of Wall components has to be written in a custom pSet (if this is a special requirement), this Network maybe provide a solution.
    Note:
    If you export Base Quantities, you get component volumes exported. Which is the normal-case to export the component quantities.
    What does the Script(s) do:
    1. The first Script creates record fields for every component Name exists in the Document (Walls have to be in the drawing, not just as a style).
    2. The Second Script gets Wall component NetVolumes and writes it in the Record attached to the Wall for every component Name.
    3. So you are able to use the Data-Manager to attach this component informations  to the Wall Body and be able to export is as a Custom pSet to ifc (if this is a requirement in a specific project)
    150 downloads
       (0 reviews)
    0 comments
    Submitted
  25. Extrude along Path with Ref point
    The standard behaviour of the extrude along path tool is to center the profile on the path and after creation we are able move it. This works pretty good. If we use the extrude along path node, is is not so easy to move the profile group after creation. This example shows how to do.
    1. Put a 2D locus point in your (blue) symbol as a reference point and put it in the background (cmd/ctrl + B)
    2. the script will measure this point and after creation of the extrude along path it will move the profile group
    Specials:
    - A custom node to get the profile group of the path
    - A custom node to reset the extrude along path object after moving profile group
    104 downloads
       (0 reviews)
    0 comments
    Submitted
