Raph
    62
Reputation
14 Good
Personal Information
  • Homepage
    standconcept.ch
  • Location
    Switzerland
Recent Profile Visitors
4,323 profile views
  1. Thank you very much for your responses, Although there are no miracle solutions, I am delighted to hear that this is an amusing problem and that the execution order of a Marionette script is unclear. In fact, strangely enough, when creating the parametric symbol, the text is placed above it. So in the end, I didn't need to create ungrouped groups. What came to mind when reading your responses is the following: Does creating “network envelopes” also affect the execution order of the script? I will test this soon. Thank you again to everyone for your interesting feedback.
  2. Hello, thank you for your reply. Yes, I can try that. I had heard that this was a possible solution. But I was wondering if there had been any developments since then. Best regards, Raph
  3. Hello everyone, I am facing a problem that many people have probably already encountered. With the help of Marionette, I draw a rectangle and some text. Unfortunately, the text is placed below the rectangle. How can I instruct Marionette to place/create the elements so that they appear in the correct order? I tried adding a node after creating the text with the code: vs.HMoveForward(h, True) But without success. Thanks in advance. Translated with DeepL.com (free version)
  4. Hello, Thanks for the answer I opened the file and did the test unfortunately it doesn't work either. Because it doesn't generate 3d parts! Can you check this by first deleting the objects created by the first code? greetings
  5. Hello, does anyone have a solution?
  6. Hello Thanks for this addition ah... it's just done with a number what I didn't understand is that the number is not visible!!! Thank you
  7. how waou How did you do it? This way is already good! I wonder if it's possible to have groups like delimited containers but ... separated this way is fine thanks
  8. Hello, Yes, that's it! I put the file in attachment AlcanForum_v1.vwx
  9. Thanks for your answers yes of course putting a number is a simple and effective solution! I was wondering if there is a solution to do it in a hidden way? I remember another parametric symbol where I tried to place a “_” before the name of the parameter entry. But it doesn't work! Another question .... is it possible to make groups? In this case, it's a matter of placing symbols on the left or right. Would it be possible to make one group for right- and another for left- heights? Thanke in advance
  10. Hello everyone, here's a new question.... I'd like to be able to make groups or, and, above all, sort the options according to my choices. Currently, alphabetical order is preferred... grrr how do I sort the item info palette? Is there a trick? Thanks
  11. Hello, Why a working script stops working after an envelope has been made. 🤔 when the script is run, extrusion is performed but once the envelope is created, there is no longer any 3D visibility profil Connection 90deg 1879_v2forum.vwx
  12. Hello everyone, I'd like to create a parametric symbol that extrudes a 2D surface. It seems relatively simple to me, but there's a left and a right. According to one criterion it should be one or the other Hello everyone, I'd like to create a parametric symbol that extrudes a 2D surface. It seems relatively simple to me, but there's a left and a right. Depending on a parameter, it should be one or the other. Thanks profil Connection 90deg 1879_vforum.vwx
  13. Hello everybody, Are you also experiencing problems with the new version of MAC OS Sonoma 14.5? Since I installed it, I've had display latencies on Vectorworks 2024 SP4. Do you have the same problem? Have a nice day
  14. Hello, so i tried to find the function but without success do you have a description of the function? HMove3D
