NickSolyom
    33
Reputation
9 Neutral
Personal Information
  • Occupation
    Lighting Design
  • Homepage
    solyomdesign.com
  • Location
    New York City
Recent Profile Visitors
  1. https://geotech.one These folks know all about how to do this!
  2. This is perfect! It at least gets me the result I need
  3. Hello! I have a document where all of my dimensions are made using the ASME Dual Stacked standard, with Millimeters and Feet & Inches. For legibility I need to change the Fraction precision on the Feet and Inches, which I have done using this control (photo below). HOWEVER, this change does not update on all my myriad of dimensions. How can I "refresh" all of my dimensions to take this setting, without deleting and redrawing all of them?
  4. It looks like this in the referenced file
  5. Hello! My workflow uses a lot of external references cropped on design layer viewports. I'm having trouble with snapping. Nothing will respond as a snap target EXCEPT the crop bounding box of the viewport. I am running Mac Monterey 12.1, Vectorworks 2022 Sp2.1 on an M1Max Macbook pro. I am interested in any steps I can try, Thanks! Video here Screen Recording 2022-01-25 at 10.03.56 PM.mov
  6. Hello! I will certainly call the service select support when I have a chance, but my first stop is here. I work on files with heavy amounts of Bitmaps and cropped external reference viewports and I am having crashes nearly every 5-10 minutes. I am running Mac Monterey 12.1, Vectorworks 2022 Sp2.1 on an M1Max Macbook pro. These crashes happen during saving, panning, zooming, and exiting crops. I have attempted an installation repair, which yielded no improvement. I am interested in any additional steps I can try, Thanks!
  7. Solved by the filter!
  8. Hello, In Version 2022 SP2.1 running on Mac Monterey on a M1 Max MacBook Pro, The navigation fails to display sheet layers that exist. I have attached a screenshot here showing the Organization window side by side with the Navigation Pane.
  9. Hi All, Any other PC enthusiasts out there? NVIDIA and AMD both have new GPU's out there. If you had to choose ONE for vectorworks on PC, which of you choose the 3080 and which of you choose the 6800XT?
  10. Hello, When using a multiple view pane configuration, is there a way for a saved view to record the state of all of the open panes? I can only get saved views to work with one pane. Thanks! Nick
  11. Hello! I wanted to share my personal style of drafting booms and ladders, and get feedback on how people are integrating schematic views. This would appear to be a perfect candidate for schematic views because I have 3 separate pieces of 2D geometry that I have to remember to keep updated. However, the single most important element of a fixtures symbol, the calibration circle, is not present in 3d models. I need that calibration circle to determine the ladder dimensions to make sure the unit will actually fit! A second problem is that moving lights will have a speed rail that is 2" tall, then the clamp attached to that. I have modified all my symbols to show that speed rail so I can build my ladders precisely and tightly. To my knowledge the 3d models don't show that speed rail. I am proficient at 3D, and would love to have one set of geometry for my ladders, but I just can't use them if it provides LESS information than 2D. Thoughts?
  12. https://www.dropbox.com/s/ampprda5fn3xhmn/2020-06-04 16-05-49.mkv?dl=0
  13. Hey Evan! Bummed that it's working for you. I'm on my Windows 10 machine FYI. Here's a video: 2020-06-04 16-05-49.mkv
