kdelvo Posted March 21, 2022 Share Posted March 21, 2022 I see the Plug- In "Elevation Benchmark" in my VWX Spotlight 2022 Plug-Ins folder. Yet, the tool does not appear in my Workspace Tools. Can't add it. Is this because it is a tool only available for Designer an/or Architect? Thanks in advance. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted March 21, 2022 Vectorworks, Inc Employee Share Posted March 21, 2022 Vectorworks Help contains a full list of the tools and commands that are available for each product. https://app-help.vectorworks.net/2022/eng/assets/docs/Commands_Tools2022.pdf Quote Link to comment
Pat Stanford Posted March 21, 2022 Share Posted March 21, 2022 And according to that table, the Elevation Benchmark is not available in Spotlight. Quote Link to comment
kdelvo Posted March 21, 2022 Author Share Posted March 21, 2022 boo. I received a drawing for a show I am working and made some edits. Need to modify some of the existing Benchmarks. Oh, well. Will find a workaround. thanks! Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 22, 2022 Vectorworks, Inc Employee Share Posted March 22, 2022 @kdelvo, Have you tried ungrouping the object? This will expose the primitive objects within the Plug-in Object. While you'll lose the "smarts" of the Plug-in, you will be able to manually edit the text and other objects manually. Also be aware that ungrouping Plug-in objects like this means they will no longer be present in the file when opened in Designer or other product that supports it (they will only see the primitive objects in the file). 1 Quote Link to comment
michaelk Posted March 22, 2022 Share Posted March 22, 2022 Or if you ever need something like an Elevation Benchmark it's simple to make your own. In the old days (3 years ago) you would use a symbol with text linked to a database. Now it's just a data tag with manual fields. 🙂 1 Quote Link to comment
