Export 2D DWG possible?
Hi there,
is it possible, like in all other 3D-CADS, to export a real 2 dimensional DWG/dxf out of a layout?
I assumed that VWX can do this and exported a layout of 5 cabinets.
The result was 200 mB big and i reduced it with help (diff settings) from Xtragroup-Support down to 38 Mb.
But why it is still 20 times bigger then it should?
I opened the file with autocad and i saw:
1. it was no 2D
2. it was a block of 3D surfaces and solids.
3. the block was 2 times in the file on different layers, on the layer like the name of my "construction level" called "Innenausbau_Konstruktion"
the layer are named as: ->
_Innenausbau_Konstruktion (3D)-1
We need for architects small 2D plans, which can sent by email.
What i can do?
br KC
  • 2 weeks later...
That was what i Tried, but one supporter meant not to use this switch
if u Read the tooltip It tells you something about a picture of the Layout.
The Problem is still, after i finally got a flat 2d of all sections i made out of the views  that the views  are still 3d, and i got this 3d 4 Times if i got 4 views.
