halfcoupler
    377
Everything posted by halfcoupler
  1. @setdesigner Here it is. Have fun ! πŸ˜€ Layher_Comfort.vwx
  2. @Jesse Cogswell awsome ! Thank you ! πŸ™‚ πŸ™‚ πŸ™‚
  3. Hi markdd, uups, one of the "hidden treasures"? Never realized that before. But you are right, not realy useful in this contex. Yes, but that's the workflow I wanted to avoid/shorten. I thougt that there must be a simplier way... πŸ˜‰ Yes, I too think that something was there some time ago. A hint in the OIP seems to be only logical. Just found that in the custom selection criteria is a "modification state", but it's grayed out, don't know if that idea leads to something.
  4. I have selected a bunch of symbols. I need to know which ones of these are flipped. Anyone knows a workflow how to identify them ? What's more, is there way to identify the axis a symbol was flipped ?
  5. yes, precisely, same here. It does not make any sense at all to create 20 or more viewports with data-vis-labels, only to go them through one by one, open them , delete the label, close, open next one,delete label, proceed ....
  6. is it correct that the automatc creation of data visualisation legeds in viewport annotations can not be switched off/avoided ?
  7. hi @ MultipleWays, YES, YES, YES, YES !!!! See my thread here, started on may 2021. Move by points became worse with VW2021, then as you mentioned, absolutely inoperable in VW2022, then slighly better than in VW2021 with VW2022 SP2 (Build 622317). It never returned to be the handy tool as it was before the tool preview was introduced. For my part I coud live very well with skipping the preview at all and having the nice move by points tool back.
  8. I think the slowliness of the resource browser, especially when replacing symbols, was first mentioned here . That is 4 years ago .... *sigh* Using the resource browser for 4 years, 50 times a day with a delay of 5 seconds that makes 100 hours of wasted lifetime. Who is going to pay the bill for that ? πŸ˜•
  9. Why on earth can I export selected rows, but not selected columns ? It forces me to always to create two worksheets, one for exporting specific columns only, and one for editing my data. πŸ™„
  10. Ahhh Great! πŸ™‚ I'm still working on VW21 here, haven't checked this in VW22.
  11. maybe its a simple trick, but cant find it: Lets say 15 objects selected. Each one has to be rotated by the Rotate Left command. Any idea how to do this in one click instead of doing 15 clicks and 15 rotate commands ? Could make a (marionette-) script for this, but I wonder if this can be done with the native tools.
  12. Ok, so we all make a demonstration march to LΓΆrrach ? πŸ˜† German support told me, serial numbers for VW2022 with dongle can't be generated at all ? So this is wrong ?
  13. That's really good news ! I'm always happy to hear that a few of the problems I experience are not located between my keyboard and my office chair. 😏
  14. Hi zoomer, I'm using this one: https://dict.leo.org/englisch-deutsch/ estabished in 1995, it is one of the oldest free dictionaries in the web. (Even older than wikipedia). Its a bit oldschool, but much more precise than Apple or Google. I think the "panel problem" is a very good example for using screen plane: First, I always end up in creating three types of panel-symbols: - "untouched" panels as they come from the manufacturer - panels with vertical and/or horizontal cuts only - special panels with cutouts and/or non perpendicular cuts. (In the end you will always need a drawing for these ones, so creating them as symbol from the beginning will help with the detail drawings later on in the project) So when it comes to distribute those panels on a facade I'm mostly using the duplicate array tool for that. (I'm not an architect, so I'm not using the wall tool at all) but I suppose this will work properly both in VW21 and VW22. And it works in both in screen or layer plane mode. Inserting a special panel at a certain point of the facade mostly can not be done via inserting symbol, since the insert point of the symbol mostly will not fit to the reference point on the facade. But if the symbols all have the same thickness (which mostly is the case with facade panels), you can simply duplicate one panel that was already placed correctly and replace it with the panel symbol you need. The new panel then is already correctly oriented in depth. Assuming the model is oriented in x- and y-axis, all you have to do now is switch to front-, back-, right- or left- view in screen plane and move the panel to the desired position, without caring if you picked the panel on the top side or backsice, and on which plane the insetion point is. If you do that in layer plane you may accidently snap to a point underneath or above the desired position, or connect the the top side of the panel to the backside of an existing panel. So this was my original question in this thread, I know there are some some workarounds to do all this in layer plane, but they all seem to take longer than the method described above. Any thoughts ?
  15. Yes, right, custom selection is more simple to use than select similar, especially if you don't know at least one object that already matches the criteria.
  16. I think this has not changed in VW 22: you can still use the select similar tool with "Plane" as Select Similar Preferance Setting to select all objets with the same (screen-)plane .
  17. Maybe I'm wrong, but this does not work if the extrude profile is a circle. In that case you can only snap to the profiles (circles) at the end of the extrude.
  18. Yes you are right, my workaround is to edit the extrude along path, copy the path, exit the extrude and insert the path at the right position. If the path is a nurbs curve you can set perpendicular working planes anywhwere along the path. Placing the profile on this working plane allows you to get the outer boundery of the extrude along path at this point and you can snap to it. hth
  19. So screen plan has become legacy now. I think it's good to have this simplyfied. But for example, when in front view, what is the simpliest way to move parts of a 3D drawing parallel to the screen without accidently snapping to points that are somewhere perpendicular to the screen ? Up to now, I haven't found a workflow that is quicker than simply moving in screen plane ....
  20. that's a wide field..... πŸ˜€ indeed the whole record attachment is not really straight forward. Im struggeling with this a lot, here are my experiences: No, not really, and yes you have to: If you have already valuables in the field you simply click on the record name, not on the check-tick. The "edit values box the gets activated and you can edit single values without touching other values. If you uncheck by clicking the check-tick and re-attach the record all field values are lost. If you want to change values for instances of a symbol that are already in the drawing, you cant do this here,- in this case a worksheet is your friend. If you are familiar with the data manager you can define default values for record fields that will be attached automatically when the symbol is inserted.
  21. What a dissappointment ! πŸ˜’πŸ˜’πŸ˜’ while VW 2021 is slow and laggy with moving by points, WV 2022 simply crashes with the same task.
  22. Just got the answer from support: VW 2022 is indeed the beginning of the end of the age of dongles ....
  23. Anyone here still using Vectorworks 2021 with a dongle like I do? Seems that VW 2022 can't be installed with dongle ...
  24. Hi Kevin, thank you for your thoughs πŸ™‚ I have tested this a lot, it doesn't matter if I'm in 3D Mode or in a top/Plan Mode in 2D. The complexty of the symbol or objects matters, but you can reproduce this problem with pure amout of simple objects: - draw a simple square - use duplicate array to draw 10,000 squares in an array of 100 x 100 squares - select all, and move this array with the move by point tool in duplicate mode so you get 20,000 squares. - repeat this => on my system VW starts to get laggy after the second copy, which is moving 20,000 squares. Seems that somehow there is a limit of calculation operations that can be handled by the move by point tool. Good idea. Where do I do that ? Is that in the preferences settings ? I think the whole problem started with introducing the tool preview. Can this be turned off ? Can't find anything in the preferance settings. Also a good idea. As a start, I will try to make the seating symbol a hybrid with a simple 2D square and move it only in 2D plan mode. My problem is that the scaffold substruction of the grandstand has to be copied too, which causes the same problem. So I will end up in manipulating all my symbols... Yes, my workaround friend is the duplicate arry tool, but you always have to identify the "move-vector" first, which slows down the drawing speed. Georg
  25. just fighted again with drawing of a grandstand with 2,500 seats, where seats are symbols. I is definitely impossible to move complete seating blocks with the move by points tool. Seems that this issue is depending on the count of objects to be moved. Up to 20 objects is working ok, but moving more than 500 objects causes my cpu to 100 % workload and VW takes almost an hour to complete the process. Killing VW via taskmanager is the only way out of this. Hope there will be a solution for this in VW 22 ? πŸ™
Γ—
Γ—
