  • 15
Structural Member usability improvements
LarryO
On 12/13/2021 at 7:40 PM, LarryO said:
8. This is a very useful one and should be a wishlist item of its own. Have a Viewport type which can generate a beam or symbol from the definition. (for placement on sheet layers) Talking 3d here and all the various views that the basic Viewport can display. This creates an easy means to annotate each beam and symbol. Avoids possibly hundreds of classes and or layers being required to control visibility. The current process of laying out beams for a structure is still required but all the layout of each beam would be tremendously simplified and can utilize templates for annotation. One only needs to remember that all symbols and beams be created at their internal origin for best functionality.
9. Having the Viewport mentioned above being able to tap into the member id and or symbol name to facilitate automatic labeling. Or would that be the other way around where labels in the Viewport tap into those ids and names?
Would it be possible to PM me examples of drawings sheets you usually create like this?
1 hour ago, Mark Aceto said:
I would like to upvote this VE but I don't see it.
I believe that VE reference number is an internal Enhancement tracking number for Vectorworks staff, tying their internal tracking system back to the Wishlist request item on the user forum.
All we end users see on the forum is just that number which refers to this thread. If you upvoted this thread at the upper left, then you have already upvoted it.
On 12/13/2021 at 4:40 PM, LarryO said:
10. Profile size should be editable as a pull down at the root level of the OI, not embedded behind a shape selection button.
Not to mention the complete workflow:
  1. Copy VW Library folder/file to User Library
  2. Open library file
  3. Duplicate Wide Flange symbol, and rename
  4. Edit Wide Flange (PIO)
  5. Save library file
  6. Refresh libraries
  7. Then... select that file from the OIP Settings
I would suspect that this is just a matter that they have not yet coded in the ability of the joining member to select/remember which axis that it will be aligning with in the other member. In the case of joining to a ridge or valley the top centre axis of the joining member would need to switch to alignment with the top edge axis of the valley or ridge member. Which is really just incorporating an offset from the bearing member's primary axis; in this case half the member width. In the case of a steel member this would of course be further impacted by the connection node design, that node could also impact the offset or wind up being an intermediary object between the two elements. In the obvious sense that would be one or two steel angles bolted or welded between the members or a less obvious modeled construct that is solid subtracted or added into the junction, like a knife plate and flange coping with holes for bolting.
I am simply happy that after more than ten years to finally witness development to the structural steel components. It will take a bit of trial and error on the part of the programmers to code this effectively. I don't imagine that any of them have assembled steel to gain grades for their C+ coding classes. Autodesk has always had the upper hand because engineers could only turn to products other than VWs to do their design work. VW users would have to import or redraw everything. And we all know the joys of importing other file formats. Try importing something from Tekla.
Yes, it feels like it's not something that would be too complicated to add so perhaps we will see it some day.
On the other hand, the unpredictable behaviour of auto-connected members shown in my video in the post above, is more problematic and I would describe as a bug. I think this tool may now be usable for me but only with auto-connect mostly turned off. Definitely an improvement compared to a couple of years ago though.
I've just revisited this in 2023 SP3 and I don't think anything has changed from my comments above, based on testing in SP2.
@Matt Panzer are you able to give us any hints on whether we will see any further improvements soon - and also, I think there are some bugs that need to be addressed. Downloading the file I attached to the post further up should make it easy to replicate some of the things you can see happening in my screen recording.
We are actively looking at other usability improvements to the Structural Member but it's unlikely we'll see anything until the next major version.
As for the bug shown in the video.  While I did find some similar bugs on this, I went ahead and submitted another (VB-193909) with your file and video.
Thanks for the response.
...and I'm also having loads of problems trying to use "custom" member types where I choose a custom 2d symbol for the shape. Editing the 2d symbol doesn't seem to change the structural members that use it, unless you switch to another symbol and then back again. And it refuses to let me select certain symbols. I can't reliably replicate this in a clean file, and haven't currently got time to pin down something replicable. For now I'm considering the custom shapes unusable.
On 3/10/2023 at 5:34 AM, line-weight said:
Another bug for you @Matt Panzer.
Combining a longways "start" offset with a negative Z offset for the axis creates this:
File attached.
Bug reported (VB-193955).
Thank you for the file and explanation!
I still need to look at the custom shape issue...
Some more structural member odd behaviour.
Two things shown in the video. Firstly, I just want to snap the end point of one SM exactly in line with the face of the other. It won't let me do this - in each attempt, I find the point I want to move the end point to, and click on it but it refuses to move. If I resize it by a larger amount and then try again, it seems to work, although I don't feel this is very consistent. In this case I am viewing in top/plan. I am not using auto-join.
Secondly, I move to shaded view, 3d perspective. Note how the blue handle for the end of the structural member moves all over the place depending on my viewing position.
Usually when this kind of thing is happening with SMs I do eventually get things where I want them, but the process is frustrating and leaves me feeling a little insecure that things really are where I want them.
I have attached the file if anyone wants to replicate.
structmemberssnap.vwx
On 12/14/2021 at 12:40 AM, LarryO said:
6. The ability to lock in a slope angle when altering the length of the member is also valuable for sloping steel roof and canopy structures; As is being able to set an angle as an alternative to setting an end elevation.
It's very frustrating that we still can't lock the slope angle whilst adjusting the span or length of a structural member.
The most simple operations become much more convoluted than they need to be.
On 12/15/2022 at 12:26 AM, line-weight said:
4. It took me some time to work out that that "auto join members mode" button, which only appears when you select the SM tool, affects adjustments to already existing members, not just new ones you are about to draw with the SM tool. If I am, say, resizing a SM then I will have the selection tool active, not the SM tool, so it won't be visible. This is illogical. That button should be up in the top right along with the "auto join walls" button (which, to confuse matters further, has exactly the same icon, but does a different thing).
And, not having used the SM tool in anger for a few months, this is tripping me up all over again. Had to come back to read this thread to remind myself how to stop SMs auto-connecting when I don't want them to.
We've switched from framing members to using structural members as they allow you to apply a material so we can pull carbon footprint data from our models.  Unfortunately, SM don't have some of the features I came to like with framing members (locking the pitch and bearing inset for rafters).  Perhaps they're hiding somewhere I've missed in VW 2025; if anyone has any suggestions, I'd appreciate hearing them.
No, unfortunately improvements to the SM tool seem to have stalled at the moment.
For "locking" pitch my only workarounds are
(a) change the length of the member in the OIP rather than graphically
(b) switch to a 3d view and adjust the length graphically while holding the shift key (doing the same in a top/plan view does not preserve the pitch!)
On 12/14/2022 at 4:26 PM, line-weight said:
1. We need a graphical clue which is the "start" and "end" of a SM, when it's selected. Otherwise it's guesswork whether we need to edit the start or end condition. Don't we get a little starter triangle with walls, for example?
This is still an issue in Vw2025. Complete guesswork about which end is which…
Other improvements to add on the list for Structural Members.
  1. Ability to define how the SM looks in 2D — exactly as we could with the Framing Member, especially Centerline only. Currently the only option is to show the Width.
  2. Ability to show 2D joist hangers — just like the Framing Member. 3D also would be nice, but I’d be happy with 2D.
  3. Better control over how the SM auto-join with other SM. Like saying in the SM Style to always butt join, not mitre 45.
Just on this point there are quite detailed appearance settings in the 2D Attributes pane where you can define how the SM will look at, below + above the cut plane, including options for the centreline. You can choose here which particular graphics get shown so can for example exclude everything else + just display the centreline, or you can include everything + instead control what you see on the Design Layer + in Viewports by class.
I don't believe VW has a clue about how structural members are actually specified and used in real-world designs, for example starting with basics which VW still hasn't gotten even close to correct over more than the past decade:
- (total) beam/rafter "length" should be assumed to be the total required length of the beam/rafter parallel to itself and be computed based on a specified (unsupported) "span", "pitch", plus any specified start/end offsets typically supporting said beam (themselves based on their defined geometry);  defining a beam length based on the graphical end-points of the geometric top/center/bottom shape representing said beam is asinine.
- (unsupported) "span" should be assumed to be defined by unsupported lateral distance (either numerically or implicitly if associated supporting end-points) parallel to the ground (not the beam itself); I personally would also like to see "total span" computed and displayed including any specified start/end offset geometry (including supporting bird-mouths and/or terminating bevels, etc.).
- "pitch" should be assumed to be specified (not computed), beam pitch is tyically defined by the designers, it's typically not a function of start/end support heights, but rather visa versa (required support start/end heights are typically a result of a beams specified "span" and "pitch", not visa versa).
Overall VW was clearly developed and apparently now also maintained by graphics folks with little construction/structural knowledge, who apparently still presume beam characteristics are a consequence of specified support/wall graphical heights and distances between them, while in fact support/wall heights are typically the result of specified structural design requirements (as such it may be a nice option to have supporting wall heights specified by the the beam support height specification, being how wall heights are typically determined as structural requirements typically define the dominant constraints).
