halfcoupler Posted November 3, 2021 Share Posted November 3, 2021 maybe its a simple trick, but cant find it: Lets say 15 objects selected. Each one has to be rotated by the Rotate Left command. Any idea how to do this in one click instead of doing 15 clicks and 15 rotate commands ? Could make a (marionette-) script for this, but I wonder if this can be done with the native tools. Quote Link to comment
Andy Broomell Posted November 3, 2021 Share Posted November 3, 2021 This was added as a menu command in 2022. Prior to this I believe someone on these forums may have written a script to accomplish this... 4 Quote Link to comment
halfcoupler Posted November 3, 2021 Author Share Posted November 3, 2021 Ahhh Great! 🙂 I'm still working on VW21 here, haven't checked this in VW22. Quote Link to comment
Pat Stanford Posted November 3, 2021 Share Posted November 3, 2021 Or try the script in this thread. 2 Quote Link to comment
KingChaos Posted November 11, 2021 Share Posted November 11, 2021 @Pat Stanford sounds interesting, You know whether it is possible to rotate a Text around a specific point in angles y or x axis or both? Quote Link to comment
Pat Stanford Posted November 11, 2021 Share Posted November 11, 2021 The easy points to get on text objects are the insertion point and the four points on the bounding box. You could use any of those as the point to rotate around. But Rotate uses polar (angle only) coordinates, so X axis/Y axis don't mean a lot for rotations. Quote Link to comment
KingChaos Posted November 11, 2021 Share Posted November 11, 2021 I need the one Text vertically Quote Link to comment
KingChaos Posted November 11, 2021 Share Posted November 11, 2021 8 hours ago, KingChaos said: Hi there, i got a marionette, placing cabinets and i need a text on the top surface (cabinet height) which display the depth of the cabinet. The red (name) and green text (Width) is placed well, after a few trys and errors. But i am not able to move the blue text (Depth) into specific z value. (the blue text should be here) Which node i can use, or why it wont work? BR KC PS: it would be great to know in addition, how to make a Text (magenta) on the side of the cabinet, displaying the "height". Quote Link to comment
KingChaos Posted November 11, 2021 Share Posted November 11, 2021 (edited) Workaround, extrude that text 0.1 mm and rotate it 3d? Edited November 11, 2021 by KingChaos Quote Link to comment
Pat Stanford Posted November 12, 2021 Share Posted November 12, 2021 You need to figure out how to get a Working Plane on the location you need the text and then put the text onto that working plane. Sorry no time to help with specifics today. 😞 1 Quote Link to comment
Pat Stanford Posted November 12, 2021 Share Posted November 12, 2021 On 11/11/2021 at 4:24 AM, KingChaos said: @Pat Stanford sounds interesting, You know whether it is possible to rotate a Text around a specific point in angles y or x axis or both? I finally understand what you are asking. And working planes are still the answer. I think of Text as a "screen plane" (not really, especially since that term and functionality is being deprecated), so rotate only makes sense around a point. You are thinking more in terms of text as bing a "sign". That sign could be flat on a wall. It could be rotated so that one end is on the wall and one end angled out. It could be rotated so that the top edge is on the wall and the bottom edge angled out. Or any variation of those. Make a working plane at the position and angle you need and put the text on that plane and you can get the desired results. And the working plane functionality applies not just to text but to all "2D" (rectangle, circle polygon, poly line, text, line, dim, etc.) VW objects. They all exist on a Plane. If you want them lifted off of the Layer Plane or angled away from the Layer Plane you have to create a working plane in the proper orientation and put the objects on that plane. HTH Quote Link to comment
KingChaos Posted November 13, 2021 Share Posted November 13, 2021 Yes, but if i have 10 objects with Different heights it will result in 10 working planes. Is it possible to make a text in the y-z plane? Quote Link to comment
KingChaos Posted November 13, 2021 Share Posted November 13, 2021 A ok working plane not construction layer, i understand Quote Link to comment
KingChaos Posted November 13, 2021 Share Posted November 13, 2021 U got some hints, where i find the nodes for working planes? Quote Link to comment
