Hello Community!
This Thursday, October 21st, from 6 pm to 7 pm EDT, we will be performing an update on the Vectorworks Community Board. During this time, the site will be unavailable.
GLASS LEAF DOOR SOLID NOT TRANSPARENT - for some reason my glass leaf in the door comes out solid - and the side lights are solid as well - the glass in the windows is clear - so that is working
gvictoria1
4 answers to this question
I had similar in the very past.
AFAIK it was that the Class, used for Glass Material assignment had "use Class properties"
check box not enabled, so the glass geometry was still on a random Attributes or Materials setting.
I think it is exactly the same problem.
Check/Edit your Glazing-clear Class if "Use at creation" is activated.
(I see it is not always, when Glazing-clear gets generated automatically)
If it is not activated, it can be that the object still uses another Material.
You would need to explode/ungroup your Door PIO to check what
Material is used in reality.
AFAIK, if you activate that Setting for a Class afterwards, VW will ask
if it should change already existing objects to the Class Settings.
Accept that and your door panel glazing should get the Material of the
Glazing-Clear Class.
