gvictoria1
    14
Everything posted by gvictoria1
  1. Is there a way to generate an index for my cover page that reflects the Sheet Layer callout in the Navigation viewer - the same way the Sheet Layer description is reflected in the title block of the sheet - thanks -
  2. I'm looking through old posts- see muntins in round and oval windows on the wishlist - any chance I missed the update and it's possible to do? thanks - gvic
  3. To clarify - at this point I'm not rendering- I'm walking through the model - which is when the moire happens - also wondering when I'm exporting an elevation - the line weight of the "shiplap" is darker than I'd like it to be - is there a way to adjust the line height of a particular 3D object in a 2D image? thanks
  4. I’ve been trying to get vertical boards - shiplap - or perhaps a wide beadboard - texture on the walls of my 3D model — I’ve built 3/4” x 6” boards - and given them a rd over- placed them 1/8” apart - and still getting some moire effects which are kind of annoying - wonder if there’s any 2D texture to apply to the walls? Or a better way to build in 3D? Attaching an image of what I'd like the walls to look like -- thanks
  5. So this fragment is stuck in my file whenever I go to a 3D view - it doesn't show up in plan view - I have closed and opened the file and the fragment has not gone away - I erased the window that it is referencing and it is still there!!!!!! I'm showing the OIP as well - ungroup - erase - tried to put it on a non plot class - nothing. Help - thanks
  6. Hi - A colleague has purchased a Blender Model - and has exported to STL - which I should be able to import? It's a huge file - 552 MB - VWX keeps freezing - anyway to import his model? thanks
  7. I am so missing the ability to adjust the size of the text in the drawing label from the OIP - Drawing # -= Drawing Name - Scale- now you have to dig two levels deep to change the size of the text and you can't do for the individual label - you have to edit the actual style - I like the ability to save styles - that's great - but I think this trade off is extreme - Does anyone have a simpler way to adjust text sizes?
  8. I've been trying to edit the path of a profile - when I go in to edit path - it tells me that the path is a nurbs curve - when I move a line - I come up with an error saying that the object I am trying to edit is invalid and do I want to delete it- a bit frustrated not sure what I'm doing wrong? including screenshots to see
  9. I'd like to fill the jamb and trim in the door tool - I also have a sidelight - and do not want to fill the glass area- including pic of door tool with a hatch fill - (it fills all) - a pic of what I'd like to see - I've had to draw rectangles on top of the tool and fill thoughts- thanks
  10. Well I'm working on 2020 - so there goes that theory :))
  11. THE WHITE SQUARE IS MY 81/2" X 11" SHEET LAYER - MY BOSS COULDNT PRINT SO EXPLODED IN ILLUSTRATOR- NOT SURE WHY HE'S GOT ALL OF THIS EXTRA INFO?
