I'm working on my workflow and there are still little things that I don't understand...
A cut wall takes its component attributes and a wall beyond the section line takes its wall attributes. Somehow, this logic doesn't work on slabs. Why ? Am I missing something ? Is it a bug ? Is it as it should be ?
My general problem is the following :
Objects that are beyond section line need to have thin lines (0.05-0.10)
Objects that are cut by the section line need heavier lines (0.18-0.25)
Important objects (like structures) that are cut by the section line need even heavier lines (0.35-0.50)
I haven't found yet the way to do it ! How to achieve this ? This is something I need to produce proper architectural plans.
A workaround I am still using is to set a class attribute for Object Beyond Section Line in Advanced Properties. Issue with this workaround :
- Surface Hatch will have the same color as other objects beyond section line (but it is a no go because I want my surface hatch to be colored and other objects to be black)
Please see below a commented screenshot to illustrate my issues...
I would appreciate your help and/or advice on best practice.
Stéphane
Hello,
19 answers to this question
