unearthed
388 -
Calendar
Everything posted by unearthed
I'm on VW2018 and want to use the Zone of Visual influence tool but there seems to be no way to show the result. The too-brief help file says the result appears but I see nothing other than my model. Also there don't seem to be any settings other than "click on the model to choose location"
Help please - convert vwx file to dwg
unearthed replied to Elizabeth23's topic in General Discussion
dwg 2012 220322_Thornhill Master Model dwg2012-dwg.zip -
Well if you can get someone to get a 2018 version I could save backwards. Crazy we are forced to do this - it's predatory software and this is essentially just a data pack, should be like swapping a font or shp file.
Is it possible to access the saved views dropdown via keyboard shortcut - and if is how?? I would expect if that's possible I could navigate via up/down arrows and select views.
If you are planting trees/shrubs between the buildings landscape architects should be first as civil usually don't think about soil.
Also VWs worksheet is so undocumented, sometimes things that should work just don't. I've got a long text file of solutions from working with it since ~2006.
Reading about having items pop up on here - It would be very useful to me if I could hover over / or click on -a plan location, and have my image/s taken at that location pop up. Is this even possible? I have not tried doing as wouldn't even know where to start. I'm on 2018, Landmark, windows.
I came here to ask the same question - am using 2018, I was hoping to colour a cell green where another cell exceeded a threshold number. Back to Excel I guess.
- 5 replies
- worksheet
- formatting
(and 1 more)
Tagged with:
Topic for new ideas - How to personalise your UI
unearthed replied to FBernardo's topic in General Discussion
Yes, fellow sufferer here, good idea to discuss. My main screen's 520mm wide x 293 high - sideways is fine but VW wastes 36mm at the top and 15mm at bottom, many of my sites are multiple km across and I need every mm I can get. I used to customise VW a lot but it reliably doesn't keep settings between upgrades so almost none now except shortcuts. I keep all palettes on another screen, but even then VW is not palette-context aware and palettes stay hidden even when active. That said VW is the best for landscape design - there's a whole herd of CADs out there that are very poor performers for the sort of landscape I do. I design landscapes, some smaller gardens but most jobs are a hectare at least, and increasingly to sub-region-scale so I need all the screen space I can get. I don't use rendering so that some clutter gone - normally hand or digital watercolour is sufficient. -
Yes, there's too many tools that have fixed 'options' (an oxymoronic eh). Most of my tools have .ini's and other scripts I can edit for stuff like this.
Export to KML - Model not visible on Google Earth
unearthed replied to Julia79's question in Troubleshooting
This may only partly answer tour question but: get a .kml you know that works, and a VW generated one and open them as text in a text editor and see if the VW one looks very different - that may tell you what is wrong. -
I've tried several and all, so far, seem fine in windows. Vectorbits is a bit of an unusual website though, in that they run instances of previous websites - complete with all software; it takes some getting used to. I tend to search it using google like: voronoi site:.vectorbits.org as the pages' own search doesn't always find everything
At it's most basic " when switching between paper and model space" this is usually due to the vp settings with some classes set to OFF. Can be tedious finding the cause with multi-class objects.
Vectorbits have a plugin that will place circles on a Voronoi patter (a type a randomness, or naturalness) http://www.vectorbits.org/VectorBits_2011/donationware/Entradas/2011/1/9_Voronoi_PIO.html I have played with it and it's really good, and simple. There's a marionette node, that prob. does more than you need: https://forum.vectorworks.net/index.php?/topic/42135-node-example-for-filling-an-area-with-symbols/#comment-211794 I have not tried this, but the discussion there suggests there's a good workflow.
"The sooner you give up on changing Vectorworks", and this is true of working with any CAD; it's about picking the right tool and then setting your mindset for that tool, all CAD's differ on some many levels so with VW you need your VW hat on, likewise with ACAD, Rhino, Sketchup etc.
click on class object and get name of class as txt
unearthed replied to unearthed's topic in General Discussion
HI Matt, Most often to drop into a worksheet for calculations, also to drop into external text editor for various things.- 6 replies
- 1
- classnames
- class
(and 2 more)
Tagged with:
A script to do that would be amazing Pat, it would be very welcome.- 6 replies
- classnames
- class
(and 2 more)
Tagged with:
Thank Pat, I'm on 2018 (have just updated sig), I'll try ROUND, INT leads to a string of characters to mitigate the round down default. Is their a Reference that states what's under the hood for all the functions? I don't really want to know but VW (especially) has taught me it's dangerous to assume.
- 5 replies
- worksheets
- int
(and 2 more)
Tagged with:
When I select an object (esp. polylines/polygons, lines) I often want to get the class name as text but VW makes this difficult as I have to get out go to navigator and select there (all very manual). I would have expected Properties to do this it but it has been forgotten there too. Is there a faster way?
- 6 replies
- classnames
- class
(and 2 more)
Tagged with:
I've been playing with INT in a worksheet this morning and realised it always rounds down so: =(INT(9.1) =(INT(9.9) both round to 9 Which result in us having to do a bit of number wrangling to get the correct result. e.g. michaelk in 2011 As a non-programmer can someone tell me what VW is doing here?
- 5 replies
- worksheets
- int
(and 2 more)
Tagged with:
Worksheet combining reference from another cell and adding text
That perfect, thanks Michaelk.
