Zeno
Panorama Non-Blocking render
As I remember, the first version of panorama did not allow user to continue the work with vectorworks. The following versions solved this problem, but actually seems that if you calculate a panorama everything is locked and you have to wait the end of process.
Or did I miss something?
490201365_Schermata2020-01-17alle07_01_49.thumb.png.23872e67ba621c82e6ab4a048614c4f3.png
I've found it best to leave the heavy lifting to VCS and process there. That does mean that you file must be stored in your VCS folder, or dropbox with full access. There have been issues with VCS saving the completed Pano in the VCS folder even if directed to save elsewhere.
It takes time to process. A JOG will show up too quickly, but not be the final output.
On 1/17/2020 at 5:10 PM, Luis M Ruiz said:
Try calculating the panorama in the cloud
no way. Problems are solving actally
There is a way to continue using vectorworks during a panorama elaboration, same as rendering a viewport, or not?
After that.. where did the opportunity to create an openGL Panorama go?
Currently, Panoramas are not exported as OpenGL, there is already an improvement request in place.
theres a workaround, when you click on save/render (in export panorama above) it saves an opengl version in place before the final render - just rename this image to keep the opengl version
