- 0
Enterprise with VW 2019/2020 and latest Drivers
2 members have voted
1. Does your Enterprise work and show all available VW Commands ?
VW 2019 with Driver 10.6.3 - works fine :)0
VW 2019 with Driver 10.6.3 - does not work1
VW 2019 with Driver 10.6.0 - works fine :)0
VW 2019 with Driver 10.6.0 - does not work1
VW 2020 with Driver 10.6.3 - works fine :)0
VW 2020 with Driver 10.6.3 - does not work1
VW 2020 with Driver 10.6.0 - works fine :)0
VW 2020 with Driver 10.6.0 - does not work2
I don't get my 3DConnexion Enterprise working on Windows.
I think it was ok at the beginning, but corrupted with the release of
the buggy 10.6.2 Driver. It was taken back soon from Downloads
and replaced with the former 10.6.0 Driver for some time.
Now 10.6.3 Driver was released and I hoped that it will work again.
But it doesn't.
I remember similar Problems when VW 2019 was released.
I was able to repair these problems
(only about 12 Commands without Names and Icons available
under Vectorworks App Driver Settings Folder)
At that time I was able to repair it by duplicating the VW 2018 XML
in 3DConnection Folder in App/Roaming/ and replacing everything
2018 with 2019.
But that doesn't work anymore for me, neither for VW 2019 nor 2020.
As long as I use my old corrupt 2019 XML, when accessing Driver Settings,
they will switch from VW APP to a "3DxSmartUI.exe"
(which I think is the Driver Settings App itself)
Deleting all VW XML entries will keep VW App active in Settings while editing
but no Vectorworks App Commands Folder available, to assign buttons from.
Or if it is there, it has these 12 number entries without Icons only.
If it works for you,
could someone please attach his Vectorworks.xml from
C:\Users\user\AppData\Roaming\3Dconnexion\3DxWare\Cfg
that I can take a look at it.
Edited by zoomerShare this post
