Chris_W 1 Posted September 15, 2019 Hey everyone -- Curious if anyone has a favorite small plotter? I'm looking to buy something for my home office that can do Arch D 36"x24" prints. Quote Share this post Link to post
ColinW 41 Posted September 16, 2019 I use a Canon ImagePrograf TM-200, it's hard to describe as small but it's quick and produces outstanding results on most media. Table top or you can get a stand. Uses Pigment inks so they don't run when they get wet. I have been very happy with this machine. I've had HPs, Epson and Canon over the years and in my experience Canon has proved to be a good brand. 2 Quote Share this post Link to post
Chris_W 1 Posted September 19, 2019 That looks like quite the machine! Awesome note on using pigment inks, I'll have to keep that in mind. Quote Share this post Link to post
Claes Lundstrom 67 Posted September 20, 2019 On 9/16/2019 at 5:06 PM, ColinW said: I use a Canon ImagePrograf TM-200, it's hard to describe as small but it's quick and produces outstanding results on most media. Table top or you can get a stand. Uses Pigment inks so they don't run when they get wet. I have been very happy with this machine. I've had HPs, Epson and Canon over the years and in my experience Canon has proved to be a good brand. Have one too. Works fine once installed and running, though the installer of the drivers for Mac could be way better. The installer pretty much needs a Canon technician to make it work. Quote Share this post Link to post
jnr 126 Posted September 20, 2019 I have an HP T520 36" that has performed quite well. Also not small but anything that will print D is going to have some size. Plug n play on a Mac, easy to print sheet stock (smaller sizes). Not terribly expensive and Amazon will drop it at your door. Ink readily available. You do have to take care of these things and I'm lucky I have a good HP tech who services nothing but large format machines. 1 Quote Share this post Link to post
bgoff 153 Posted September 21, 2019 A great Desktop is a T130 HP! It prints 24 wide and can sit on a desktop! 1 Quote Share this post Link to post
ColinW 41 Posted September 22, 2019 On 9/20/2019 at 9:36 AM, Claes Lundstrom said: Have one too. Works fine once installed and running, though the installer of the drivers for Mac could be way better. The installer pretty much needs a Canon technician to make it work. The installers are fragmented so the process isn't as straight forward as it should be although I didn't have any issues (on a mac), I've previously had a large format Canon so that may have helped. Quote Share this post Link to post
Markvl 187 Posted September 24, 2019 (edited) This is a pic of an HP T120 probably similar to the T130 above. What I like about this model is the 11x17 feed tray that you can see at the back. Edited September 24, 2019 by Markvl 1 Quote Share this post Link to post
Chris_W 1 Posted September 25, 2019 Sorry, I've been absent from this conversation! These look like great options! ...I never thought I'd be so excited to spend this much money on a printer, but here we are! :p @Markvl - The extra feed tray is pretty slick. Curious, do you know if you can create a publishing set that will use different trays for different sizes? What about using different printers? I'm travelling without VWX at the moment so I can't check myself... Quote Share this post Link to post
