Steve Clarkson
Rendering Times on Design Layer vs Sheet Layer
Hi All,
Wondering if there's something I can do to help with this...
I create a Realistic Exterior Fast render in the Design Layers.  It takes about 4 minutes, reasonable, looks good, so I click Create Viewport and assign it to a Sheet Layer.
I go to the Sheet and click Update - only changing Scale beforehand.  This render takes an hour (!?!?!?!).
Anything I can do?
The Design Layer render is at 72dpi, the SLVP has an assigned DPI, that might be 300. The increase is exponential.
Screen Rendering is only (a typical olf Monitors resolutio) 72 DPI.
If you would render a SLV with the same coarse Pixel amount
it would also render in 4 minutes.
So you can only lower your SL DPI resolution or decrease your SLVP's
size. Or you try to optimize Materials and Render quality.
Things that take a lot of render time and should be used with care
and only where necessary are :
Blurry Reflections
Antialiasing
Caustics
