142 -
Reputation
6 NeutralPersonal Information
Occupation
Event Production Manager with Sherwood Systems, Kitchener, Ontario
Location
Canada
Recent Profile Visitors
Light Instrument Data Appearing in Different Places
Steve Clarkson replied to Steve Clarkson's topic in Entertainment
Thanks, much appreciated! -
I've been playing with this some more, and I'm very confused now. My thinking is that I need to "open up" the stock symbol, add the lens (and a graphic I created to differentiate it), and then "close it back up" and have it be a lighting device not just a symbol. So far my attempts at various un-grouping and, record detaching and reattaching, have failed. But I'm going to keep at it, and may just have to resort to typing all the data in from scratch. I'm still interested in any and all advice. Cheers. -
Steve Clarkson changed their profile photo
Hi Again, I've begun taking the VW stock instruments that we use the most often and adding a lens to them for the realistic appearance of light in the fixture. That has all gone great. What's happening is that once I've created the final symbol and Converted to Instrument on the Spotlight dropdown, the data fields appear on the Shape tab, while the original stock instrument has the data on the Data tab. This in itself isn't much of a problem, but next I want to copy the data from the originals to the modified ones using either the Lighting Symbol Maintenance report, or, find a way to copy the Light Info Record from one to another (rather than typing everything out individually). My new, converted instruments are not present on this report, and I can't find a way to copy the Info Record from one to another. I've attached a VW project file to illustrate. Ideas? Thanks, Steve. Info_Record_Test.vwx
Rendering Times on Design Layer vs Sheet Layer
Steve Clarkson replied to Steve Clarkson's topic in General Discussion
Our purse-string-controllers only wanted a one-time investment to start with. 😉 -
Doh! Right of course... Yes, the cloud would be awesome, not in our budget currently.... unfortunately. Thanks! -
Hi All, Wondering if there's something I can do to help with this... I create a Realistic Exterior Fast render in the Design Layers. It takes about 4 minutes, reasonable, looks good, so I click Create Viewport and assign it to a Sheet Layer. I go to the Sheet and click Update - only changing Scale beforehand. This render takes an hour (!?!?!?!). Anything I can do?
Jim, Thank you so much for all your help. While I come from some past exposure to drafting, this was the first CAD software I'd ever touched, and in just over a year you have been instrumental in getting me up to speed such that VW has become a very important part of my company's work flow. Sorry to see you go, but we all should also take a lesson from your example of quality of life above work. Cheers, and all the best!
General non-functionality on Laptop
Yes, from what I've read about this model, the onboard Intel cannot ever be taken out of the equation, you can just tell it to the 1050 when necessary. Data is sent to the 1050 to process and then renders go back to the Intel to pass on to the display. This certainly isn't ideal. Probably cost cutting in some way as far as design. -
Thanks All for the help on this. I did learn that even when using the 1050 GPU, the Intel GPU is the connect between it and the rest of the computer. The Intel decides what to pass off to the 1050. Things are still workable for "in a pinch/snow day/work from home" tasks, but as a main machine, it's not very happening. Cheers. -
I've had good/decent usability on my office computer (spec's in signature) with 2018, but I'm now trying to use my laptop, the spec's of which shouldn't be that far off in performance. -
Thanks Art V I'll check that. Yes, In the NVIDIA Control panel I have both the global and application preferences set to the High Performance (NVIDIA) GPU. And I am getting very good usability now with navigation in 3D WIreframe and OpenGL, but VW itself, menus, copying/pasting objects, selecting etc is painfully slow. -
Ok, thanks! -
Ah, sounds good! So would this GPU issue explain all the hanging I'm experiencing? Even just clicking a dropdown menu? -
Thanks for the assist again, I'll keep searching. Cheers. EDIT: Though I found this interesting.... Look at the Ambient Occlusion setting. -
lol, ya I tried that (device manager) already, got things back to staus quo though.
