Andrew Mac Posted December 12, 2018 Share Posted December 12, 2018 Is it possible to make this shape with my wall? Quote Link to comment
cberg Posted December 12, 2018 Share Posted December 12, 2018 (edited) I would say no. This is as close as I could get. Unfortunately, the wall tool is not really 3D. Edited December 12, 2018 by cberg Quote Link to comment
Kevin McAllister Posted December 12, 2018 Share Posted December 12, 2018 I was able to get this close - You can't quite make the end point. I'm not sure you'd want to overlap the points because it may start to misbehave. Start with a wall the correct length in plan, switch to a 3d view and double click on the wall. This will give you a tool to move or add points. Kevin Quote Link to comment
cberg Posted December 12, 2018 Share Posted December 12, 2018 That''s better than I was able to achieve. Nice! Quote Link to comment
markdd Posted December 12, 2018 Share Posted December 12, 2018 Always like a challenge! Quote Link to comment
cberg Posted December 12, 2018 Share Posted December 12, 2018 I figured it out too. You create two shapes and fit wall peaks to one of them. And base of wall to another. 1 Quote Link to comment
Kevin McAllister Posted December 12, 2018 Share Posted December 12, 2018 28 minutes ago, cberg said: I figured it out too. You create two shapes and fit wall peaks to one of them. And base of wall to another. I'd be curious if the resulting wall has two overlapping points at the pointed end.... Kevin Quote Link to comment
cberg Posted December 12, 2018 Share Posted December 12, 2018 It's pretty pointy at the end! As long as you line it up in plan. Not sure how Markdd got it to work. 1 Quote Link to comment
markdd Posted December 12, 2018 Share Posted December 12, 2018 @cberg Kevin’s method seemed to work fine for me, allthough yours is ingenious! Quote Link to comment
Andrew Mac Posted December 12, 2018 Author Share Posted December 12, 2018 okay looks good- Here is the area I need to make one wall. I currently have two walls to make the shape above. Is it possible to join the lower portion the left side of the wall to turn left into another wall? See example Quote Link to comment
