Andrew Mac
making an odd shaped wall
I would say no.  This is as close as I could get.  Unfortunately, the wall tool is not really 3D.  1151477511_ScreenShot2018-12-12at12_22_38PM.thumb.png.7aa6121d4087c1a28aa817af3bc91c7e.png
Edited by cberg
Share this post
Link to post
I was able to get this close -
28218873_ScreenShot2018-12-12at9_38_06AM.thumb.png.92f584cbdef627f85ea28cde63614c86.png
You can't quite make the end point. I'm not sure you'd want to overlap the points because it may start to misbehave.
1445688103_ScreenShot2018-12-12at9_38_33AM.thumb.png.cf52c8b06a027b8a8a385a5a23b65890.png
Start with a wall the correct length in plan, switch to a 3d view and double click on the wall. This will give you a tool to move or add points.
Kevin
Share this post
Link to post
I figured it out too.  You create two shapes and fit wall peaks to one of them.  And base of wall to another.
1242926327_ScreenShot2018-12-12at1_36_43PM.thumb.png.02d2ea75b0f1ce921670616583141ce4.png
Share this post
Link to post
I'd be curious if the resulting wall has two overlapping points at the pointed end....
Kevin
Share this post
Link to post
It's pretty pointy at the end!  As long as you line it up in plan.  Not sure how Markdd got it to work.
825427077_ScreenShot2018-12-12at2_15_17PM.thumb.png.9c1513e03504b7d798afe8a66d9a13b8.png307532644_ScreenShot2018-12-12at2_15_43PM.thumb.png.84c418d1dfd574512fcd3ba4673f2e1c.png1201172697_ScreenShot2018-12-12at2_15_49PM.thumb.png.74256c6b1e4ca8f0514e85b478295f9e.png
Share this post
Link to post
okay looks good- Here is the area I need to make one wall.  I currently have two walls to make the shape above.  Is it possible to join the lower portion the left side of the wall to turn left into another wall?
See example
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
