td4stage Posted September 25, 2017 Share Posted September 25, 2017 I am not finding "U Address" in the OIP in Spotlight 2018. This is one of the fields that needs to be there according to http://www.mckernon.com/supportmenu/vwdataexchangeaddr.html Or am I blind. Thanks, Pat Quote Link to comment
Vectorworks, Inc Employee klinzey Posted September 26, 2017 Vectorworks, Inc Employee Share Posted September 26, 2017 @td4stageU Address is only shown when "Automatically assign Universe" is selected in Spotlight Preferences. When "Automatically assign Universe" is enabled "U Address" will be shown and the "Universe" and "U Address" fields will be disabled. These values will be automatically calculated based on the absolute address entered in the "Address" filed. 1 Quote Link to comment
Jeff B Posted September 29, 2017 Share Posted September 29, 2017 I'm confused as to how this works with Lightwright though. John McKernon gave a set of instructions which I won't include all of here, but the last few steps (underlines added by me) are: 13. Set the options in Vectorworks to match those outlined in red here [the illustration shows selecting the "Universe / U Address" button in the "Options" tab of Lightwright, VW Data Exchange] This tells Lightwright to look at the Universe and U Address fields, and to ignore anything you type into the Address field. 14. Choose the .xml file created in step #9 and Lightwright will read the data from the Universe and U Address fields. It will automatically fill the Address field in Vectorworks with correct entries in universe format. 15. Click back on Vectorworks, it will read in the Address field changes that Lightwright made. 16. Save both the .lw6 and .vwx files. From now on, edit only the Universe and U Address fields in Vectorworks. Do NOT edit the Address field in Vectorworks, Lightwright will take care of that. So if U Address only shows up when you ask Vectorworks to "Automatically assign Universe," but John is telling us not to touch the Address field and only edit the Universe and U Address fields, well, maybe I'm just tired at the end of a long day but it seems like something isn't quite lining up correctly? Or is it just me... Thanks Quote Link to comment
td4stage Posted October 1, 2017 Author Share Posted October 1, 2017 On 9/26/2017 at 8:47 AM, klinzey said: @td4stageU Address is only shown when "Automatically assign Universe" is selected in Spotlight Preferences. When "Automatically assign Universe" is enabled "U Address" will be shown and the "Universe" and "U Address" fields will be disabled. These values will be automatically calculated based on the absolute address entered in the "Address" filed. Thanks Kevin. Is there somewhere that more thoroughly discusses the pros/cons to either manually or automagically assigning Universe? Quote Link to comment
LVLDME Posted December 18, 2018 Share Posted December 18, 2018 @Jeff B You can always add the U Address field to your OIP by going to Spotlight preferences, lighting device and lighting device parameters. You can add or take away most of what you see in your OIP. You can do that without having the automatically assign universe feature enabled. I am having the same issue with lightwright btw. I use the auto number in vectorworks to assign Universe and address at the same time by clicking a chain of units. However when I follow the lightwright instructions it puts a 1 in the universe column on lightwright although there are many different universes displaying correctly in vectorworks. I guess I just have to change the way I address and display patch in vectorworks to get it to communicate to lightwright. Did drawing in vectorworks with the U Address field solve your issue? Quote Link to comment
Sam Jones Posted December 19, 2018 Share Posted December 19, 2018 Go to the help menu in Lightwright. There is a document there describing exactly how you need to use the fields “Universe”, U Address”, and “Address”. Failing to follow those directions screws up their use with data exchange. Quote Link to comment
