I am calling this a bug - though I am sure the engineering team will disagree.
Right now the drawing stamp that the new title block border tool creates is below all other objects. This means you can not put the notice for NOT FOR CONSTRUCTION on top of your titleblock - it needs to find some empty space somewhere. This should be changed to where the stamp is forward of the title block. As if, as the name implies, you were stamping and extra notice on your sheet.
I tried to link a text box to the drawing stamp record - but that does not work. All the formatting is messed up and if you use a Custom name - the linked text reads Custom rather than the input.
The work around is simply to create your own Project drawing stamp field and link the text to that.
Tom Klaber
7 answers to this question
