zoomer 687 Posted September 1, 2017 At least if you a select contract (?) - AMD Pro Render (Visualize/Broadcast/Studio only) and such things : https://www.maxon.net/en-gb/products/new-in-release-19/r19-complete-feature-list/ Quote Share this post Link to post
mjm 131 Posted September 2, 2017 Dang. Pretty. It'd be great to see a full quality render posted here Zoomer, if you wouldn't mind, noting render machine, duration, quality. thanks Quote Share this post Link to post
zoomer 687 Posted September 2, 2017 (edited) I can't overdo it at the moment as my CPU has to do important 100% C4D CPU Rendering and using both D700s made my nMac Pro start smelling strange Although iStat says everything green by max *60°C (* 140 in funny units) And there is no (optimized) Demo Scene provided by Maxon. I have only standard C4D Material Scenes and there seems no way to convert these into Pro Render PBR Materials. Edited September 2, 2017 by zoomer Quote Share this post Link to post
zoomer 687 Posted September 2, 2017 (edited) I don't get it. Enthusiasm little cooled down after hours of playing. 1. I find no option to control brightness (not supported) deactivated in Cameras 2. Remaining Aperture Setting doesn't really influence DOF for me 3. No Material Overwrite or any conversion Option for C4D to PR Materials 4. nMac Pro gets really hot with dual D700 usage 5. I find no PR demo scene 6. Maxon misuses their tabbed Material Editor UI since their new Reflection Model, it is no fun at all to scroll for everything through the Reflection Channel. And even worse, they only deactivated all non supported (faking) settings in that PBR workflow but do not hide them from users. But R19's OpenGL Advanced Viewport DOF addition is nice. Edited September 2, 2017 by zoomer 1 Quote Share this post Link to post
EAlexander 200 Posted September 3, 2017 If you want amazing render engine that works on the trash can Mac, look at Corona. It's free now while in development. Easy, cpu based, and gorgeous. Ipr is coming (already in the road map and working in Max). I played with prorender on Friday for a bit. Better then I expected, but can't hold a candle to Octane. Quote Share this post Link to post
zoomer 687 Posted September 3, 2017 (edited) 16 hours ago, zoomer said: 1. I find no option to control brightness (not supported) deactivated in Cameras It has to be done by Tone Mapping in the Render"Style". Not really the control I need, especially if I need completely different exposure settings for each of my many cameras. BTW, there is a PDF from AMD that explains a bit more than Maxon did and resembles my experiences more : https://www2.ati.com/relnotes/radeon-prorender-with-maxon-cinema-4d.pdf 10 hours ago, EAlexander said: If you want amazing render engine that works on the trash can Mac, look at Corona. Always thought that would be another new GPU Renderer. But it has to be quite good, as I heard it will be bought by Chaos Group (Vray). Both renderers will exist further beside each other but they do a lot of technology transfer back and forth. Which I think is very cool. Edited September 3, 2017 by zoomer Quote Share this post Link to post
zoomer 687 Posted September 3, 2017 To summarize, ProRender does work with standard C4D Materials in existing Scenes. Just that you will get its full potential and better quality by using the new PBR Materials Vice versa you can use the new PBR Material System with your standard C4D Physical Render "Styles". Quote Share this post Link to post
Gadzooks 105 Posted September 3, 2017 18 hours ago, zoomer said: Enthusiasm little cooled down after hours of playing Ahhhhhh..........a little like a Vectorworks upgrade? 2 Quote Share this post Link to post
zoomer 687 Posted September 5, 2017 Played a little more with ProRender. Still get similar fasts results with CPU-only Rendering (VRAY or Modo). But it is ok in general. I like grain and noise. But I still have no success with transparencies, like some Window Panels behind each other. No matter what Ray Depth, Geometry cleanup, pure PBR Material, .... These stay grainy and even worse darken unnaturally. Quote Share this post Link to post
barkest 152 Posted September 5, 2017 I understand not everything is implemented in prorender due to the core rewrite so it's a case of waiting for r20 I really found the reflective channel overly complex and confusing. The integration with substance painter is painful and throw in the poor additions to BP and ....... Quote Share this post Link to post
zoomer 687 Posted September 6, 2017 (edited) Yes, if new features are implemented and UI integration and its adaption or evolution gets forgotten, it doesn't need much time until you have a total mess. Happens in Modo since the implementation of render passes as well as currently in C4D. I tried again transparency in a file from scratch where arranging rounded edges cubes behind each other worked well without (unrealistic) darkening. Thought I may be a problem only when objects aren't parallel and did another cube row with different angles. But that also worked well. Just in my File with glass panes from Door or Window PIO's they render nearly black with same render settings. I don't quite understand that as I am used to correct the Glass Panes geometry mostly after an Import. Of course PIO's glass panels have wrong Face Orientation as the are made from Extrudes and Frames/Sashes tend have strange extra vertices or 1-2 point polygons. But I did the "Optimize" and "Align" commands already a few times and Face Orientation is double checked. Deactivating Refraction IOR doesn't change anything so I assume it is about the reflexions. Edited September 6, 2017 by zoomer Quote Share this post Link to post
EAlexander 200 Posted September 7, 2017 Zoomer, make sure your glass panes don't have a phong tag. That can mess up flat glass at rendertime sometimes. Quote Share this post Link to post
zoomer 687 Posted September 7, 2017 That was a really good idea ! Unfortunately not solved the problem in my case. But yes, the Phong Tags, if applied at all, should be set to newer C4D defaults, = 40° (+ Angle Lock ?) And I do not really understand when and when not they get applied to which objects. With the 40° setting and angle lock, they do at least not harm. A bit worse for 3rd party renderers, or better I have only problem with these are the Normal Tags applied to some objects. They have no meaning, they just harm and I wish they weren't there. Normally correcting these is part of my normal Optimization Work after import. But indeed forgot it in this case. While testing changes there were some temporary inconsistencies like IOR problems although face orientation ok, maybe also cache update problems. And I would say, in my case, the reflection of the darker interior on windows is a bit off. Quote Share this post Link to post
zoomer 687 Posted September 7, 2017 That is what I mean by problematic refractions. But at least much better than in the first image on top of this thread .... Quote Share this post Link to post
PVA - Jim 2,314 Posted September 8, 2017 Just for my own interest, are all render engines that can be used in conjunction with C4D designed to go all the way to a finished product? Is this engine somehow designed only to get MOST of the way there quickly, but they intend for the other engines to be used for a last run? Or is it more that this engine was released ASAP and that it needs nover revision or two to bring it up to feature parity with the other engines? Apologies if this is an ignorant question, still learning the ins and outs of C4D when I have the time. Quote Share this post Link to post
zoomer 687 Posted September 8, 2017 (edited) It is another 3rd party Render Option. Mainly GPU in this case. It still has not all features, maybe some small bugs and implementation will improve over time. So a version 1.0 for now. It is meant as your final Renderer if you like it. And well integrated into C4D by Maxon itself, while VRAY is neither implemented by Maxon or Chaos Group itself but by an Austrian company in Vienna. Other than Modo where Chaos Group does the VRAY implementation and so the integration may be a bit deeper and faster. Other C4D 3rd party Renderers may also be more or less compatible, integrated and ready for release. Edited September 8, 2017 by zoomer 1 Quote Share this post Link to post
EAlexander 200 Posted September 8, 2017 2 hours ago, JimW said: Just for my own interest, are all render engines that can be used in conjunction with C4D designed to go all the way to a finished product? Is this engine somehow designed only to get MOST of the way there quickly, but they intend for the other engines to be used for a last run? Or is it more that this engine was released ASAP and that it needs nover revision or two to bring it up to feature parity with the other engines? Apologies if this is an ignorant question, still learning the ins and outs of C4D when I have the time. My take - and purely speculation - I think they realized it was important to catch up to the current GPU render engine offerings before they get any further behind the curve. They released it half baked to get it going quickly and refine it in future releases. With the core rewrite, the current rumor mill is that R20 is going to bring huge changes. We'll see. Pro Render is existing tech, so they could bolt it on and then fine tune the integration instead of building completely from scratch. I think a lot of people and studios are still using Physical renderer, but the visibility of Octane and Redshift can't be ignored for GPU power and quickness of workflow. Once you get a true IPR experience when creating lighting and materials, it is really hard to go back to the old ways. Then you have things like Corona and Arnold starting to really show what a CPU render engine can do (fast IPR, simple settings) and I think they wanted to try and keep up with this trend somewhat as well. If you look at the work being generated in Cinema, it feels like most of it is happening now via 3rd party - but I don't have actual numbers. Also - Pro Render is slated to work with AMD GPUs which Octane, Redshift, and other CUDA based engines can't do - so I think they are trying to get something to the Mac users and get their foot into that niche. Personally, I'm full in on Octane and Corona and for the first time in 12 years am back on a Windows machine with multiple GPUs and overclocked cores. I haven't done a job in Physical renderer at all in 2017. Pro render isn't really of interest to me, but I see why they are doing it. I don't always like how Maxon deals with things, but they are very smart and it is the most stable software I've ever used. 2 Quote Share this post Link to post
zoomer 687 Posted September 8, 2017 1 hour ago, EAlexander said: Also - Pro Render is slated to work with AMD GPUs which Octane, Redshift, and other CUDA based engines can't do - so I think they are trying to get something to the Mac users and get their foot into that niche. Probably its best Feature. Also I like the use of open standards. And it will combine and work AMD and NVidia Cards. So you can take an AMD for Bitcoin mining and a 1080 for gaming and Cuda, Prorender will use everything. And it looks like NVidia isn't as bad in Open CL as one would expect. My first GPU renderer on macOS + AMD. (beside Luxmark) Quote Share this post Link to post
zoomer 687 Posted September 5, 2018 C4D R20 : AMD Prorender (on Metal) is good and useful finally. And also the Advanced Viewport seems gotten very fast now ! (Also that is still old legacy OpenGL) BTW, using ProRender with CPU (or both) is still marked "experimental" Quote Share this post Link to post
Selin 41 Posted September 14, 2018 On 9/5/2018 at 9:39 AM, zoomer said: BTW, using ProRender with CPU (or both) is still marked "experimental" Yeah, because ProRender is an open source engine and it's free, I expect that it'll be tweaked a little in every release and some features will stay 'experimental' for a while. I couldn't get a chance to play with R20 yet. How do you like the new node based UI @zoomer? Quote Share this post Link to post
zoomer 687 Posted September 14, 2018 I think I have to get used to it for Blender anyway. But it is a bit like VW would have "Marionette Materials" (Or do we already have ?) Honestly I prefer the limited and simple Material Editor UIs where I can check everything in one Panel. The way how C4D was in the long past, where you separate Tabs per Channel deactivate and hide unneeded Tabs. Or like VRAY, or like the reduced PBR Settings for Game and Realtime Engine Exchange all 3D Apps offer Nowadays. Or like Modo where all your Physical Materials Settings fit mostly into 1 Panel while the whole complex Texture Options reside external in the Shader Tree. I think in a Node Editor, even the most simple Material Setups, look much more complicated than they are. Like Navigating in a complex Building's Floor Plan where zooming and panning needed. It doesn't look that bad in C4D though. I haven't much played with Material Node Editor in C4D nor Blender, but used it in rare special cases in Modo in the past, where the Node Editor isn't for Materials only but anything. Although I haven't had much fun with my first Marionette trials, Node Based Editing is something that I will certainly not refuse in the near future. Quote Share this post Link to post
