djobbins 0 Posted January 17, 2017 Hey guys! This is probably a really easy answer but I can't figure it out for the life of me. I have a drawing which is based around a design layer viewport that is referenced from another drawing, with a bunch of my layers and classes drawn in on top. It's a floor plan from a designer in the referenced file, and then my file has all my cable paths, fixtures etc. My question is that I want to make multiple sheet layer view ports with certain layers/classes turned off within the design layer viewport. So, for instance within the design layer VP there is a 1st flr, and 2nd flr layer. I need to make 2 sheet layer viewports one showing the design layer viewport w/ the 1st flr layer, and one showing it with the 2nd flr layer. Thanks! Quote Share this post Link to post
Pat Stanford 1,631 Posted January 17, 2017 Only 2 options. 1. Import/create all of the class names from the Referenced file into your work file and then check the Use Current Document Class Visibilities button in the Classes dialog box for the referenced viewport. If there are a lot of classes this can clutter your class list and make the file harder to work from. This will allow you to use Class Overrides in the Sheet Layer Viewport to control the display of the referenced data. 2. Create a second Referenced Viewport for each set of visibilities you need. You will then use overrides as needed in each of the Referenced viewports to set the visibilities as needed. Ask if you need more information. 1 Quote Share this post Link to post
Tom Klaber 741 Posted January 19, 2017 @Pat Stanford Is (1) really true? I did not think class overrides in a sheet layer viewport would ever affect a design layer viewport. @djobbins I think you are going to need a copy of your DLVP for each view you want to create. Quote Share this post Link to post
AlanW 547 Posted January 19, 2017 @djobbinsHi, in the attached files copy both to the same folder. Open file 2 and check that the exref to EXRef file is updated. In fiule 2 there are 3 viewports each reference the same viewport. It appears that only the classes from the exref that you want to alter need to be imported and as you choose them from the viewport in the design layer VW will ask you if you want to import them. So yes you can have one Exref viewport of another file and have as many viewports as you want and you can change the classes in both files through the one viewport. PS Make sure all objects are set to by class. HTH EXRef File.vwx File 2.vwx 1 Quote Share this post Link to post
Tom Klaber 741 Posted January 19, 2017 This is going to change everything! Quote Share this post Link to post
Tom Klaber 741 Posted January 19, 2017 12 minutes ago, Alan Woodwell said: @djobbinsHi, in the attached files copy both to the same folder. Open file 2 and check that the exref to EXRef file is updated. In fiule 2 there are 3 viewports each reference the same viewport. It appears that only the classes from the exref that you want to alter need to be imported and as you choose them from the viewport in the design layer VW will ask you if you want to import them. So yes you can have one Exref viewport of another file and have as many viewports as you want and you can change the classes in both files through the one viewport. PS Make sure all objects are set to by class. HTH EXRef File.vwx File 2.vwx Nice demo file. All this requires is the same class names? Quote Share this post Link to post
AlanW 547 Posted January 19, 2017 If you want to change the exref globally and not have the classes imported I would go t the exref viewport and change the classes through that viewport. Quote Share this post Link to post
AlanW 547 Posted January 20, 2017 @Tom KlaberHi, Here is a file with the same classes in the separate ex referenced files. Takes a bit of concentration to get your head around the way to manipulate the references and viewpoints but once you get it you can do a lot with a single viewport. HTH EXRef File.vwx EXRef File_01.vwx File 2.vwx 1 Quote Share this post Link to post
Tom Klaber 741 Posted January 20, 2017 I guess because we typically deal with consultant files, and never wanted to bring those classes into our document - we never had this capability. I am embarrassed that this turned into me thinking that it wasn't even possible. Quote Share this post Link to post
AlanW 547 Posted January 20, 2017 @Tom KlaberTom, Nothing to be embarrassed about here, its all about learning what the program can do and how we can use it. The best part about this Forum is we can all ask question and make comment and in the spirit of collaboration we can all share and progress our knowledge. I hear so often at work that the program has a bug, it doesn't work, well some times maybe, but generally the user hasn't had the time or willingness to research the solution. Keep posting as I read all your posts as I always learn bits from you ans everyone. Quote Share this post Link to post
Tom Klaber 741 Posted January 20, 2017 @Alan Woodwell Only embarrassing because I have been using it for 10+ years and I was explicitly hired to head the VW BIM transition. It's a bad day if you do not learn something new. 1 Quote Share this post Link to post
AlanW 547 Posted January 20, 2017 @djobbinsHi Regarding your original post how to have your consultants file show all as one, sorry got sidetracked but in the attached files I have placed the exref viewport that could be your consultants file and used layer colours to make all one colour of your choosing. HTH EXRef File_01A.vwx EXRef File_A.vwx File 2_A.vwx Quote Share this post Link to post
tim_o 0 Posted April 11, 2019 Just resurrect this question - is the same possible with levels somehow? Turning levels on and off in a design viewport that contains information from a referenced drawing? Quote Share this post Link to post
