Just found out (again perhaps) that the text size in Vectorworks is not about capital X-height as in AutoCAD but about line height (incl. ascenders/descenders etc) which is correct by itself.
This means that a text size specified as 2mm height ends up as 1.4mm in a dwg file for e.g. a capital X in Arial, i.e. as 70% of what you thought it would be.
Can the text size setting for Vectorworks be updated to have an option to make it match the way it works in AutoCAD, i.e. apply to capital X-height and not line height?
As it is now it's tricky to conform to text sizes specified for dwg based drawings as Vectorworks uses line hight.
Importing text from a dwg gives the correct point size, so theoretically it should be possible to define it in a similar way from "AutoCAD mm" to points.
Edit: corrected for initial mistake re text size based on x-height vs line height and updated request for matching the AutoCAD way of specifying text height
Art V
Edited by Art VLink to comment
7 answers to this question
