Phil hunt Posted December 12, 2013 Share Posted December 12, 2013 i am having great difficulty in modelling this item of furniture for a project i am working on, any advice ? Quote Link to comment
Phil hunt Posted December 12, 2013 Author Share Posted December 12, 2013 ps am i adding the attachment correctly ? Quote Link to comment
michaelk Posted December 12, 2013 Share Posted December 12, 2013 Attachment added correctly. Hard to tell from that picture, but I think it could be done with a solid addition of the seat and the sides and then filleting all the edges. mk Quote Link to comment
Phil hunt Posted December 12, 2013 Author Share Posted December 12, 2013 cheers this is the file so far, did it with a shape and then extruded added a few chamfers just can't get the tapered look quite right. Quote Link to comment
CipesDesign Posted December 12, 2013 Share Posted December 12, 2013 Just curious, have you looked through the Knoll Furniture resources? I seem to remember seeing something similar in there... Quote Link to comment
Phil hunt Posted December 12, 2013 Author Share Posted December 12, 2013 no peter but thats a great idea i can usually use a model but this is quite specific to the client as they have had this furniture purpose made for the job Quote Link to comment
Phil hunt Posted December 12, 2013 Author Share Posted December 12, 2013 had a look at knoll but just not quite there such a difficult chair to model could i convert mesh maybe or would that complicate the geometry to much ? Quote Link to comment
VincentCuclair Posted December 12, 2013 Share Posted December 12, 2013 Try searching Google warehouse for the make and model, you can import SketchUp files into VWs. Quote Link to comment
michaelk Posted December 12, 2013 Share Posted December 12, 2013 could i convert mesh maybe or would that complicate the geometry to much ? I've had better luck using mesh models as references for modeling, rather than using the mesh models themselves. Mesh and 3D Polygon models tend to cause problems. (see this thread for an example: http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=38896&Number=192816#Post192816v) hth mk Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 12, 2013 Vectorworks, Inc Employee Share Posted December 12, 2013 Something like this? Mostly just used taper face to get the angling right, kept a copy of the raw geometry before the fillet too just in case, since fillet loses edit history: Quote Link to comment
Bas Vellekoop Posted December 12, 2013 Share Posted December 12, 2013 You can ungroup a fillet, right? Then you have your history back I thought? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 12, 2013 Vectorworks, Inc Employee Share Posted December 12, 2013 I just do duplicates as a habit so I can go back and forth and compare, but you're right, it can be ungrouped as well as a kind of undo action. Quote Link to comment
Phil hunt Posted December 12, 2013 Author Share Posted December 12, 2013 Jim that's a great way to do this I guess a simple subtraction of shape over the main model would do this to get the seat area I'll give this a go but thanks so much for your advice and help Quote Link to comment
Phil hunt Posted December 16, 2013 Author Share Posted December 16, 2013 this was the finished result....trial and error....just needs a bit more softening to make it right ! Quote Link to comment
