Alan H Posted November 16, 2012 Share Posted November 16, 2012 Just wondering what the logic behind this is, I don't make any changes to the model but after a PDF batch I have to update viewports? Quote Link to comment
michaelk Posted November 16, 2012 Share Posted November 16, 2012 I've seen this, too. But it doesn't happen on every file. Maybe it's related to the size of the file? If you have a file that always does it, please submit a bug. mk Quote Link to comment
billtheia Posted November 16, 2012 Share Posted November 16, 2012 I, too, noticed that VW2013 required VP updates for no apparent reason. That, coupled with too many crashes and general bugginess, has pushed me back to VW2012. Quote Link to comment
michaelk Posted November 16, 2012 Share Posted November 16, 2012 I've had exactly the opposite experience. For me, 2013 crashes much much less and runs faster than 2012. I think that the export PDF/viewport issue also happens in 2012. I've often wished that a Vector Script call was available to turn off the viewport update indication. If you change the graphic attributes of a section line, the viewport that section line generates indicates that it needs to be updated. If you change the price of something in a worksheet, then all viewports with the symbol whose data changed show that they need to be updated. mk Quote Link to comment
Kevin McAllister Posted November 16, 2012 Share Posted November 16, 2012 (edited) If you hit undo after moving a group of sheet layer viewports around on a sheet they need to be updated?!? I agree with all of MichaelK's observations, they often need updating for no reason at all. I have seen weirdness after a batch PDF export in 2013. Once it piled all of the viewports from all of the sheet layers visually on top of each other in their wireframe form. When I refreshed the view, all of them disappeared again except the ones on the current sheet layer. There is something not right about the update viewport command in 2013, but I haven't seen anything repeatable to Bugsubmit. I actually wish there was an Update Viewports on Current Sheet command. Kevin Edited November 16, 2012 by Kevin McAllister Quote Link to comment
barkest Posted November 16, 2012 Share Posted November 16, 2012 There are issues with 2012 as well. After a batch PDF export two of my walls moved on top of other walls in the viewport. I thought it was a minor glitch but now realise its an issue. Only happened once but I now save before batch export. Quote Link to comment
Assembly Posted November 17, 2012 Share Posted November 17, 2012 When I batch export in 2012 the screen 'locks' into the current view. I have to change layers to a design layer, then rotate the 3D view for the screen to refresh. Quote Link to comment
Alan H Posted November 20, 2012 Author Share Posted November 20, 2012 (edited) I've seen this, too. But it doesn't happen on every file. Maybe it's related to the size of the file? If you have a file that always does it, please submit a bug. mk This seems to happen with all my files, i'll submit one as a bug when i get time. I also find that i need to sometimes update viewports after i go into an annotation layer as well, again i don't see why this action should require updating viewports either. Edited November 20, 2012 by Alan H Quote Link to comment
