Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
rita
won't render
I have set up my model to have a different design layer for each floor, when i render although only the floor that i am on renders. how can i render all layers so i am able to see the building as a whole?
Thanks
Rita Schooley
In model setup I have selected 2 floors and 0 basements ,the layers of mod- foundation,mod slab-1,mod-floor-1,mod-slab-2,mod floor 2,mod-roof are created when giving heights in next step.I have created each floor in the appropriate layer using wall tool and the foundation/slab by extruding a solid because of this it only ables one layer to render while the rest is in wireframe.makes it difficult to understand the creation as a whole. I assumed there would be a way to render all layers? It also creates difficulties when creating a sectional perspective to render all layers.
Thanks
The Layer Options allows you to view/modify different layers differently.
If you right-click on a blank space on the drawing the contextual menu will offer Layer Options - select this, then select View Others or View Snap Others or View Snap Modify Others so you can see all layers at once.
Rita, create an empty layer intended specifically for rendering. On that layer create a layer link, that links to all model layers (Later you can add layer links for props/plants/furniture/garden etc.) Make sure that layer options is set to active only. Set up lighting and render. Thats it.
Rita
Layer links is an outdated method. It is no longer included in most of the workspaces. (It is still in Fundamentals.) Design layer (or sheet layer) viewports are a much better method.
However, you shouldn't need either to render.
Make sure you have the layers you want to show up visible (not grey) and the layer options set to Show Others or Show/Snap Others.
Make sure Unified View is on.
Make sure your objects have a solid fill.
Render away.
hth
mk
Hi
I had this problem too, you need to go to the navigation palette, and chose view all layers not tray out layers
