taoist Posted July 4, 2011 Share Posted July 4, 2011 Would be great to know how to create a batt insulation hatch to use as wall fills at creation. Going through the process of 10's of levels in the hatch editor as it does not do "arcs" or circles is quite tedious. taoist Quote Link to comment
0 CipesDesign Posted July 4, 2011 Share Posted July 4, 2011 Detail tool set, Batt Insulation... Quote Link to comment
0 taoist Posted July 4, 2011 Author Share Posted July 4, 2011 Peter, Thanks, I know about that. This does not address the issue. Why should we have to select a tool to draw in insulation as a wall fill? It should be one of the hatch patterns just like brick, concrete, stucco and such. I can see (to a degree) the need for such a tool when drawing details. taoist Quote Link to comment
0 Ernestas Mozeiko Posted May 21, 2015 Share Posted May 21, 2015 so there is still no way of having instalation as a hatch ? Quote Link to comment
0 rDesign Posted May 21, 2015 Share Posted May 21, 2015 The problem with a batt insulation 'hatch' is that there won't be any way to consistently have the arcs occur at each boundary of the wall assembly. The batt arcs could be in the middle of the wall, cut off at the edge, the batts won't orient correctly for a wall -vs- a floor / ceiling assembly, etc. Quote Link to comment
0 Jonathan Pickup Posted May 21, 2015 Share Posted May 21, 2015 (edited) You can create a tile that looks like batts insulation. Edited May 21, 2015 by Jonathan Pickup Quote Link to comment
0 rDesign Posted May 21, 2015 Share Posted May 21, 2015 That's interesting, I wouldn't have thought to use a tile. Thanks for the tip Jonathan. Do you need multiple widths of the batt insulation tile to work correctly with different wall cavity widths? Quote Link to comment
taoist
taoist
6 answers to this question
