Ernestas Mozeiko
    12
Reputation
0 Neutral
Recent Profile Visitors
  1. Same problem to me. Did anyone managed to find the solution?
  2. so there is still no way of having instalation as a hatch ?
  3. Hi, Without creating new topic, I thought I will ask here about double line polygon tool. Is there is way to stop it creating overall thickness polygon? If I have 2 components 1. - 120mm thickness 2. - 30 mm. And when I draw this polygon I get 3 different polygons: 120, 30 and 150mm polygons. Is there a way to stop it doing ?
  4. Here is the file: https://dl.dropboxusercontent.com/u/26088808/file.vwx It is from vw library, if vw is not capable to render it properly I do not understand why is it there in a fist place. Please post how is it rendering at yours.
  5. Hi everyone is there a way in vectorworks 2013 to count the luminance like in Dialux?
  6. Kevin I have just used random object from vw designer 2013 library. I am interested why I am still using this program. Despite the rendering it is one of the best I have used so far, what I love most about it that it got rendering machine inside and even after rendering I can change it. So I assume there is no way I can import objects and make them look photorealistic, what a shame.!
  7. The toilet I have posted before is from vw library. So it appears renderworks has ty rendering engine. Unrended sketch up object looks better then the same object imported to vw rendered.
  8. Well, it happens to any object I import either it is 3d max or sketchup, vectorworks renders it terribly. Is there any why to solve this ?
  9. Thanks for you help, but I am afraid it didn't sort the problem. It did help but it is far away from perfect. [img:center]https://dl.dropboxusercontent.com/u/26088808/Screen%20Shot%202013-09-08%20at%2016.52.27.png[/img] Any other ideas ? Or that is all what renderworks is capable of ?
  10. Hi, Could anyone please tell me why is it rendering this way? I set all settings to the max, and anyway curved objects came up terrible. How do i make smooth lines ? I have set the dpi to 300 as well. [img:center]https://dl.dropboxusercontent.com/u/26088808/Screen%20Shot%202013-09-07%20at%2011.39.02.png[/img]
  11. What I am trying to create is hidden lighting that would create nice linear light. I tried to use point lights bus it doesn't look very good as there is no continuousness between the light.
  12. Hi, is there any way of creating Neon lighting? I tried to use glow, but cant really get what I need.
