domer1322 Posted November 18, 2010 Share Posted November 18, 2010 Upon start-up, is there a way to make VW 2011 always open a blank document that is formatted according to the "Architect" template instead of always opening up a new document that has the wrong (for me) scale ? (I know i can do it myself .... I want it to happen automatically each time i start up.) Quote Link to comment
CipesDesign Posted November 18, 2010 Share Posted November 18, 2010 Open a new document, then set everything as you like, then "save as template". Next time you open a new file you template will be available in the pulldown list of new documents. Quote Link to comment
Pat Stanford Posted November 18, 2010 Share Posted November 18, 2010 I think the saved template file needs to be named Default.sta and should be saved in the User folder under Libraries:Defaults:Templates:Default.sta. Quote Link to comment
Ozzie Posted November 18, 2010 Share Posted November 18, 2010 when you Save As Template VW automatically saves it as a .sta file meaning you can have several of them for different purposes if you wish to Quote Link to comment
domer1322 Posted November 18, 2010 Author Share Posted November 18, 2010 OK ... but I think maybe Pat has the right answer. I knew I could save templates, but my question was ... how do I get my template to open up AUTOMATICALLY every time I start the program (instead of the "standard" empty document) Thanks for your help ..... Quote Link to comment
Ozzie Posted November 18, 2010 Share Posted November 18, 2010 I do not know if you can have your template file open when VW starts Perhaps someone else does Good wish though if it is not possible Quote Link to comment
Ray Libby Posted November 18, 2010 Share Posted November 18, 2010 In Vectorworks Preferences under the Session tab check the box Create a new document on startup. If you hover over it with your mouse it explains how to have a custom document open. Quote Link to comment
Ozzie Posted November 18, 2010 Share Posted November 18, 2010 Now I understand what Pat meant with default.sta - did not know that Quote Link to comment
domer1322 Posted November 19, 2010 Author Share Posted November 19, 2010 well .... now I've tried putting the "default" template in the templates folder and starting up ...... it didn't work. Am I doing something wrong ? Did anyone else try that and get it to start up with your designated template ? (I tried it on both Windows and Mac versions VW2011 ... same result... no joy) Quote Link to comment
domer1322 Posted November 19, 2010 Author Share Posted November 19, 2010 OK ... I just tried it for the third time ... third time is a charm.... it worked. The answer is to make sure you put your new template in the right file folder. Libraries>Defaults>templates>default.sta. thanks for all your help .... Quote Link to comment
Ray Libby Posted November 19, 2010 Share Posted November 19, 2010 It's working for me. Did you put it in your user folder? You named it Default.sta? Mac: HD:Users:(Your Username):Library:Application Support:Vectorworks:(Version Number):Libraries:Defaults:Templates Windows: C:\Users(Or Documents and Settings)\(Your username)\Application Data(Or AppData)\Roaming\Nemetschek\Vectorworks\(Version Number)\Libraries\Defaults\Templates Quote Link to comment
Marcelo Bernardo Posted November 7, 2017 Share Posted November 7, 2017 It's working for me.Windows: C:\Users(Or Documents and Settings)\(Your username)\Application Data(Or AppData)\Roaming\Nemetschek\Vectorworks\(Version Number)\Libraries\Defaults\Templates Nice! Quote Link to comment
