Marcelo Bernardo
    13
Reputation
0 Neutral
Personal Information
  • Location
    Brazil
Recent Profile Visitors
  1. Hello Fellows In previous versions I configured two keyboard shortcuts to create a new designer layer and another to create a new class. In Vedtorworks 2019 I can't do the same. Not possible anymore? I just found the possibility of creating a shortcut to open the layer menu, but to directly create a new layer I didn't find the shape. Please how can I do this quickly and conveniently. Thanks.
  2. I have same problem. Trying all export methods created a empty .xml file. Any ideas or suggestions?? Thanks!
  3. It's working for me. Windows: C:\Users(Or Documents and Settings)\(Your username)\Application Data(Or AppData)\Roaming\Nemetschek\Vectorworks\(Version Number)\Libraries\Defaults\Templates Nice!
  4. I understand... If I create this record is it possible to calculate the total through Vwctorworks? In my example it is easy to do in hand, however I am involved in a priojeto where this will become an inconvenience. If possible which way? Thank you in advance!
  5. Hey guys Is it possible to automatically calculate the total weight of a truss with Light Instruments and cables? Example: I have a Truss line of 10 meters with 5 Varilites Spot 3000 and cables. I put on that truss two hoist. Is there any tool that gives me the automatic calculation of the weight of this set? Thanks a lot. And sorry for my bad English
  6. Nice!! I forgot to associate the body with the rest of the equipment. Thank you!
  7. Folks Help ME!!! When trying to create a new symbol I'm encountering this problem when using 3D rotation. What am I doing wrong? Thanks!
  8. Nice! I had same problem in edit my personal library and this metod resolved my problem. I selected and edited all symbols, and after this, edit data in Light Synbol Maintenance, now the synbols apears perfect in all data sistem: instrument Summary etc... Sorry my bad english
  9. lol As I said... I am new user of the program and was using the wrong tool. Thank you very much!
  10. Hello folks! In Vectorworks Spotlight, after changing a symbol using the command: replace with symbol. This symbol does not have its data updated in the summary tools. It appears as an unused device with a count equal to zero. Even making the switch in the options: use original; use substitute... I'm doing something wrong, I'm a new user in the program Thanks to anyone who can help!
