jeharch Posted November 19, 2009 Share Posted November 19, 2009 What is the best wat to draw a curved roof? I'm designing a cabin which uses a curved tree trunk as a ridge beam. The rafters will sit on the this ridge beam creating an arch down the middle of the building. Also two outside walls will start at 5'ht and end at 10'ht and 15'ht. I tried "interpolated surface" and I got the shape I wanted but I could not extrude it to create the 3d image and I could not extend wall to this surface. Any Ideas? Vw11.5 jt Quote Link to comment
CipesDesign Posted November 19, 2009 Share Posted November 19, 2009 An interesting problem. You might try using the Extrude Along Path command to create the actual framing members. I suspect that it will take some trial and error. Have fun! Quote Link to comment
MKingsley Posted November 19, 2009 Share Posted November 19, 2009 If you're talking about creating the roof surface, you can "shell" the interpolated surface to the thickness you want. Don't know why you can't extend the walls to the surface. I can't remember what VW 11.5 was capable of. Quote Link to comment
Jonathan Pickup Posted November 19, 2009 Share Posted November 19, 2009 Shell solid toll will create a thickness with a surface. A combination of extract surface, shell solid and solid modeling (add solid, intersect sold or subtract solid) should do it. there is a nice 3D modeling manual available on the training guides page http://www.nemetschek.net/training/guides.php Quote Link to comment
bcd Posted November 19, 2009 Share Posted November 19, 2009 HI Jeharch. Great question lots of ways to solve it. I'm wondering about the connection detail between the rafters & ridge beam. Assuming (falsely) that neither rafters nor beam have cross-sectinoal area and that the beam is straight in plan I would do the following - but taking account of the material thicknesses & soffit & gable overhangs etc. In Front view, Draw a polyline representing the curved beam. Move to height & Modify>Convert>Convert to nurbs In Plan View - Draw two lines representing the paralell walls Modify>Convert>Convert to nurbs In the OIP - edit Vertices - Cycle through the vertices and enter z values for each of the corners. Switch to an isometric view Draw a Nurbs curve (degree 1) from ridge to corner & repeat for other wall Loft Tool>Birail Sweep (keep curves checked). Select Ridge - Wall line - Rafter - click green check box Repeat for other side Plan view draw walls - set height to something small eg 2' Select walls - AEC>Fit Walls to roof. Quote Link to comment
