Faceted stringers on curved stairs
It seems that the stringer on a curved stair does not accurately follow the curve of the stair but rather is faceted. Particularly noticeable when creating a spiral stair with a closed stringer and attempting to render.
I am missing a setting somewhere to remedy this problem?
thanks
This is a render-settings problem. See the image below, which I think is what you are looking for. Go to the View:Rendering:Line Render Options Command. In the dialog that appears, set the "Smooting angle" to be greater than the angle between your stringer facets. (The image below has this set to 35 degrees):
Jeffroyer's problem remains though. The stair tread have curved ends on the inside and the outside edges. The stringers however are not curved - they are in straight line segments between risers. In most circumstances this does not match the required reality.
Robert's tip for HLR gives a good result for linework views. If you render in Shaded Polygon, OpenGL or Renderworks though the facets are very obvious.
