Steven Kenzer Posted February 18, 2007 Share Posted February 18, 2007 (edited) Making the shift to 3D modeling has been a somewhat slow but very rewarding process for me. Maybe the forum could help on a quick question here. Once I have a molding element created, such as a crown piece, how does one go about mitering the corners? In other words, how would I connect and join 2 crown molding extrusions at a right angle? Thanks in advance for any info/advice concerning this. Steven www.kenzerfurniture.com Edited February 18, 2007 by skfurn Quote Link to comment
Gytis Posted February 18, 2007 Share Posted February 18, 2007 First off I would recommend searching these TechBoards: there have been various threads, bringing up various solutions to this question. In quick overview, there is Extrude Along Path (my usual solution), with the drawback of sometimes dicey path control. If you wish to work with extant extrudes, I think your option would be Split (and delete)Tool. IMHO, this would be labor-intensive splitting and placing.... You can find other solutions.... Quote Link to comment
FredM Posted February 18, 2007 Share Posted February 18, 2007 I don't do many mouldings, but when I do, here's how I do it. Create moulding profile in 2d extrude along path create 2d desired angle extrude and subtract solids. Then mirror and duplicate along the newly formed angle. It is not the best way, but it works for me. Quote Link to comment
Steven Kenzer Posted February 18, 2007 Author Share Posted February 18, 2007 Evidently this has come up before. I'll definitely search the forum.In the meantime, I just wanted to thank Fred M and Gytis for the quick response. Both replies are helpful. sk Quote Link to comment
Jonathan Pickup Posted February 18, 2007 Share Posted February 18, 2007 i would use the extrude along a path you might want to check out my 3D modeling manual as well. https://plus36.safe-order.net/archoncad/manuals/manuals.php Quote Link to comment
jeffroyer Posted February 18, 2007 Share Posted February 18, 2007 I struggled with this same issue until I learned to use the path extrude command from this forum. In top view I draw a polyline around the base of the wall following the path I want the moulding to take. I convert this polyline to a nurbs curve and then use the 3d move to locate the curve at the bottom or top point of the moulding ? whichever is appropriate. Still in top view I draw the 2d shape of the profile, select it and the path and use the extrude along path tool. The trick then is to use the edit mode to get the profile on the correct position relative to the path. Double click on the extrude and you are given the option to edit the path or the profile. Selecting the profile takes you to a screen with the profile and a ?cross hair? ? the intersection represents the line where the line is perpendicular to the screen. Move the profile relative to that point to position the moulding appropriately. You will not have to worry about creating the mitres this way and it gives you the ability to edit the profile shape later if needed. Make a copy of the profile if you need to use it more than once since the command uses the one you have drawn. Quote Link to comment
islandmon Posted February 19, 2007 Share Posted February 19, 2007 Make the inner & outer corners as 90? Extrude Along Path symbols then use straight extrude lengths for the various runs... connect the lengths to the corners. This technique is simple, easy and avoids path issues. Quote Link to comment
mike m oz Posted February 19, 2007 Share Posted February 19, 2007 Islandmon's method is the quicest and easiest method. Once you have made the two symbols required for the intrnal and external corners the rest becomes easy. Changes are easy to deal with, unlike with path objects. Once you understand the logic dealing with odd angled corners is also straightforward. If you don't want the extra lines which will occur in Hidden Line Renders then you can form the corners using extruded lengths and Split at the required angle. Quote Link to comment
jeffroyer Posted February 19, 2007 Share Posted February 19, 2007 With this method it seems that changes would in fact be more difficult to deal with. If you have used the extrude along path command you only have to change the profile once. If you create numerous extrudes for a complex room, wouldn't you have to edit each one individually? Quote Link to comment
Steven Kenzer Posted February 19, 2007 Author Share Posted February 19, 2007 Thank you all for the feedback. This is a wonderful resource. No doubt "Extrude Along Path" was the answer and, it seems to me, Islandmon's technique, straight extrusions into corner symbols, to work best. Thanks again. Steven www.kenzerfurniture.com Quote Link to comment
