219 -
Calendar
Everything posted by Steven Kenzer
I would update to 12.3.1, the most recent OS update, and see if that helps..
Apple macOS 12 Monterey Compatibility - Feedback
Steven Kenzer replied to JuanP's topic in News You Need
I upgraded my late 2015 iMac (earliest model that's upgradeable) this week to Monterey / 12.3.1. And using VW 2022/SP3. Pleased to say no issues to report after 4 days of use. -
Thanks for the file, Bruce. That is a tricky area to detail..looks like you have it all figured out. Nice work. Question....how are you liking the new M1 iMac? Do you feel a shift in efficiency and speed? Any issues with the 16gb of ram? I understand the M1 treats memory differently so curious how that's going. I'm holding out for the M1/2 27" but not sure when they'll release that.
I also had turned off "Automatic Graphics Switching in Preferences/Battery. After experiencing the frozen menu 3 times in a row, it now seems fixed. I rebooted, opened VW and the Menu function seems ok now. -
FYI....I did update my MBP to the most recent version of Monterey and using the most recent version of 2022. As others have experienced, VW Main Menu is not accessible....unresponsive to my cursor. After reading through the forum posts, I can resolve this by closing my laptop, opening it and signing in again. 😞 Hoping this gets resolved soon in an update. -
Juan & Pat, has Vectorworks given the final green light to updating the OS to 12/Monterey if using VW 2022? Should this still be done cautiously or have most issues been resolved now? I haven't seen any official announcement yet so wondering. Thanks for any advice you can offer. -
Electrical Switches, Outlets, and Cover Plate symbols?
Steven Kenzer replied to Bruce Kieffer's topic in General Discussion
Bruce, I often go to Sketchup's 3D Warehouse for stuff like this: https://3dwarehouse.sketchup.com/search/?q=outlets -
2022 SP2.1 Seems to not work (Mac OS12.1)
Steven Kenzer replied to Chris Rogers's question in Troubleshooting
I had never even noticed that "Repair" under the "Advanced Options" heading on the updater. I just ran it out of curiosity. Wow, 3303 files repaired! -
Blown away by that. Thanks for sharing.
3d dimensioning in Hidden Line not showing...
Steven Kenzer replied to Steven Kenzer's topic in General Discussion
Benson, I'm in SP2 now..forgot to update my signature. Not corrected yet. -
You should give "Smart Options" a try. The spacebar or other assigned maneuver brings up the Snapping Palette by your cursor (along with other menus). Much better than it's home at the lower right corner.
Crazy but confirmed....when I toggle from DHL line to HL all dimensional numbering appears. Thanks again, Benson. -
Thanks, Benson and yes, kind of a strange workaround to what I would think should be a standard process. -
On 2022/Big Sur now. I'm trying to understand why 3d dimensions in hidden line disappear. As I scroll in or out, dimensions show up but then vanish. I never had this issue on previous releases. Works fine in Wireframe and Shaded. I'm working on one simple design layer. I exported the file back to 2021 and have no issues with this problem. Simple fix? Thanks in advance for any help.
Hope. this helps, David.....attached is zipped folder with .dwg and other files generated from your drawing. Billingford 6_15 ODSP-dwg.zip
ATTRIBUTES Tool Window
Steven Kenzer replied to bpynn's question in Wishlist - Feature and Content Requests
and.........Was the ability to stretch the Attributes Palette in a vertical direction removed from 2022?? I can only stretch this palette horizontally now...seems odd. -
iMac 24'' M1 - empty pallets
Steven Kenzer replied to António da Cunha's topic in General Discussion
Antonio, if you let the forum know which version of Vectorworks your customer is using, that will be helpful. If it's an older version, that might be the reason for this. -
Snapping Palette in 2022 missing...
Thanks, Matt. -
I wanted to take a look at 2022 so downloaded it this afternoon and....... I'm not seeing the Snapping Palette?? Is there a trick to getting this back or might it be a downloading glitch and I need to re-download/install. Any thoughts on this? Screenshot attached. Thanks.
Lately, when I go to measure a side view of a 3d model, the dimensional slash lines don't appear..see simple screenshot. Is there a setting that is creating this issue? I've played with OIP settings to no avail. Might correspond with recent update/s. Simple fix or bug? Thank you in advance for any help on this.
I haven’t had any sensitivity issues with the MX Master either. It's been my preferred mouse since it was released several years ago. I also use "SteerMouse" a 3rd party add-on that I strongly suggest you check out. It has many settings to play with, including cursor sensitivity. Good luck.
This is one of the better and more informative threads about Rendering settings I've seen. Threads like this can be so helpful for those of us using Renderworks, whether beginner or advanced. Thanks, Zeno for initiating it (great work!) and thanks all for the terrific information concerning ways to improve and speed up rendering time.
Framing Member correct texture alignment
Steven Kenzer replied to drelARCH's topic in General Discussion
My error....I let slip you are using the Framing Member tool. I don't really use that tool for my work. Maybe some others will chime in if there's a way for you to alter texture direction. Thanks. -
Hi, Pavol. In the "Object Info/Render" palette is a rotation slider that should allow you to change the direction of the texture you're working with.
