Steven Kenzer
Content Count
199 -
Community Reputation
12 GoodAbout Steven Kenzer
Rank
Journeyman
Personal Information
Occupation
Furniture/Cabinet Designer
Location
United States
Recent Profile Visitors
1,216 profile views
Lately, when I go to measure a side view of a 3d model, the dimensional slash lines don't appear..see simple screenshot. Is there a setting that is creating this issue? I've played with OIP settings to no avail. Might correspond with recent update/s. Simple fix or bug? Thank you in advance for any help on this.
I haven’t had any sensitivity issues with the MX Master either. It's been my preferred mouse since it was released several years ago. I also use "SteerMouse" a 3rd party add-on that I strongly suggest you check out. It has many settings to play with, including cursor sensitivity. Good luck.
This is one of the better and more informative threads about Rendering settings I've seen. Threads like this can be so helpful for those of us using Renderworks, whether beginner or advanced. Thanks, Zeno for initiating it (great work!) and thanks all for the terrific information concerning ways to improve and speed up rendering time.
Framing Member correct texture alignment
Steven Kenzer replied to drelARCH's topic in General Discussion
My error....I let slip you are using the Framing Member tool. I don't really use that tool for my work. Maybe some others will chime in if there's a way for you to alter texture direction. Thanks. -
Hi, Pavol. In the "Object Info/Render" palette is a rotation slider that should allow you to change the direction of the texture you're working with. -
I deal with this daily and yes, is very frustrating. It does seem like the Renderworks cache is creating the problems. I can edit, make changes, then "custom render" and the old model pops up with none of the changes I've made present. I have found going into the custom Renderworks settings, changing that randomly, then trying again, can sometimes fix this..the key word here is "sometimes". Restarting often does the trick but I think we can all agree that's not exactly the solution anyone wants.
Single twist steel rod and bar...
Steven Kenzer replied to Steven Kenzer's topic in General Discussion
Thanks for this Benson.....very helpful. -
Hi. As far as I know, VW no longer has any type of downloadable manual but instead uses this online help area for guidance and reference: http://app-help.vectorworks.net/2019/eng/index.htm#t=VW2019_Guide%2FLandingPage%2FWelcome_to_Vectorworks.htm
Thanks for the file, Alan..that's always helpful. -
Thanks, again Kevin. I can work with this for now. -
Thanks, Kevin. I see now. The square extrusion is not a problem. I needed to do this on both a square extrude and a rod-like one. I might be able to get away with adding the square twist to the rod extrusion..will take a look at that. Is twisting the rod, with proper appearance, not possible? -
Hi, Kevin and Pat. I"m still having trouble creating the desired form and wondering if you could elaborate a little on proper technique here. The Deform tool is one I don't have much experience using. I extruded the rod and then selected the end with the deform tool. As I rotate (twist) it does this within itself so really nothing changes. How does one end up with the screw like spiral I'm trying to achieve? Thanks again for any help on this. -
Thank you, Kevin. I'll check this out later, Much appreciated. -
Hi, All. I need to create this twisted steel detail on some furniture I'm working on but not sure how to go about it. Can someone point me in the right direction to do this in regard to tools and technique? As always, thank you for any help on this.
Thanks, Matt. That worked. Layer off/Layer on/ All good. Much appreciated.
