What's a Simple Way to Lighten Up Ceilings in Shaded Render?
We use Shaded render for a lot of our work. When we present interior spaces the ceilings always appear too dark. I assume that Shaded (like Open GL) can support up to eight light sources. What's a simple way to use Shaded, but get the ceilings brighter, and evenly illuminated?
Thanks,
Ed
Thanks,
Ed
Give your ceilings a texture that has "reflectivity" set to glow with a low brightness value and set to "emit".
It's a similar trick we use to make plants, signs, and anything that needs to be a little more visible in the dark.  You just have to be very subtle with it.
Alternatively, if the ceilings aren't visible in a shot, just turn them off and it will be like a TV set 🙂.
Add lights in the space above to get the desired effect.
Oh great! The ceiling that "glows" is what I was hoping for. I'll give that a try. I'll reply again after I do, but it might take me a few days to get to it.
Thanks,
Ed
If you are just doing shaded view renderings, Lighting Options might be a more effective solution.  Bump the Ambient Brightness for real time effects.
Here are some examples of both Final Renderworks and Shaded using glowing ceilings with low intensity brightness:
Both the ceiling in the main space and the curved one in the back are "glowing"
No glow Shaded
Glow Shaded
