GETTING WRONG HATCH PATTERN AND MY CLIENT REQUIRED specific hatch AS I GENERATED IN HATCH EDIT
Set the document unit precision much higher than 1 decimal place then edit the hatch and you’ll see the offsets are not what you think due to them being rounded to the document unit precision.  That is what’s causing the problem.  Once you’ve corrected them, you can change the precision back as needed.  BTW, I believe the hatch offsets can be corrected without changing the precision by selecting each one and retyping it in.  This will replace the actual values (that are displayed rounded) with the correct value.  It’s a little weird doing it this way because the value you’re replacing looks the same (do to the rounding) as the new value.
  • Like 3
