Tobias Kern Posted February 29 Share Posted February 29 (edited) Hi VW-Forum, Is it possible to refer to a database field (type: pop-up) in a Spreadsheet cell within a worksheet and to be able to select (list) the pop-up entries in that Spreadsheet cell? Greetings and thanks for help Tobi Edited February 29 by Tobias Kern 1 Quote Link to comment
Jeff Prince Posted February 29 Share Posted February 29 That's an interesting question. I know you can edit records with pop-up values within a worksheet database, I don't know how you could do that from a spreadsheet cell. It would be handy though. Hopefully @Pat Stanford will weigh in. 1 Quote Link to comment
Pat Stanford Posted February 29 Share Posted February 29 Simple answer is no. There are no worksheet functions to display the multiple pop-up choices. More detail about what you are trying to do and it MAY be possible with a worksheet script. Here is one that takes the Record and Field names as parameters and returns the popup values. Procedure PopupDefaults; {©2024 Pat Stanford - pat@coviana.com} {licensed under the Boost Software License 1.0} {https://github.com/boostorg/boost/blob/master/LICENSE_1_0.txt} {TL/DR Use as you want, attribution for source, No warranty} {Worksheet script to provide all popup values of a Record.Field. Maximum of 50 PopupSetChoices} {Run in worksheet using =RunScript('PopupDefaults','Record Name', 'Field Name2Index} {Set to separate values with a colon as with defatul row height only the first value shows} {Change the middle of the For N2:= line from ' : ' to CH R(10) (without the space) to put on separate lines} VAR Rec, Fld, S3:String; N1,N2:Integer; A1: Array[1..50] of string; BEGIN Rec:=WSScript_GetPrmStr(0); Fld:=WSScript_GetPrmStr(1); PopupGetChoices(Rec, Fld, N1, A1); S3:=A1[1]; For N2:=2 to N1 DO S3:=Concat(S3, ' : ', A1[N2]); WSScript_SetResStr(S3); End; Run(PopupDefaults); @Jeff Prince are you a magician? I was 30 seconds from posting when your post came through. But then the Forum bug that won't let you use certain (CH R) text strings in a post caught me. 😉 3 Quote Link to comment
Tobias Kern Posted February 29 Author Share Posted February 29 Hi Pat, thanks for that solution, I will try it tomorrow. It late here in Germany! I wrote a request for my idea to VW Inc, I think there is a use for it. Hopefully we'll get access to pop-up lists in spreadsheet cells soon. Greetings and have a nice rest of the week Tobi 1 Quote Link to comment
Silvano Posted March 23 Share Posted March 23 Excellent topic. For smaller tasks, you can also organize the record format data in the first few rows of the spreadsheet and use the VLOOKUP function with a few absolute address cells; if you prefer, these rows can be hidden with zero height. For more robust work, you can make a spreadsheet with just this data as a reference source, for inclusion in the pop-up fields of the same RFs and other uses. Marionette networks also work well for this, including with data from different spreadsheets, but it is better to combine them with h/vlookups in the reference spreadsheet itself if there is a lot of data and changes. 2 Quote Link to comment
