I've had this trouble before and found some unhappy work-around that I cannot remember.
There seems to be 100 dimension types in the OIP and none of them are what I want, and 90% of them are exactly the same. I'm sure this is some kind of accumulation of template garbage.
When I attempt to change the arrow size in the document settings-dimension standards - custom ... NOTHING happens.
I've tried various other routes but nothing I do seems to change it apart from merely selecting another Dim Std., which isn't appropriate either.
I've made new standards, attempted to edit existing ones, closed and re-opened the document. Nothing. Nada, Zip.
The dims are in the Dimension class, and drawn in the annotation layer in a VP.
Bug? Feature? PEBCAK?
Surely there must be an easier UI than whatever VW has now.
Why can't the OIP just have a simple "Marker Size" control!?!?!?!?!
Can I just state for the record that the dimension controls in VW are GARBAGE.
Since nothing else works I may have to find a style with no practically visible marker and literally draw a triangle to be 'the arrow' for my arc radii, to be the correct size.
Perhaps I might also just go back to drawing everything on tracing paper with pens and razor blades to scrape off mistakes.
DSmith2300
Sigh...
I do feel like such a moaning pain sometimes.
3 answers to this question
