Ben3B Posted December 15, 2023 Share Posted December 15, 2023 Hello I can't find where I was speaking about that in 2023 ;( and I put both name singular and plural because the both are in the manual and in the forum, so may it helps for reseach In 2023 with the new graphic legend tool, I was very happy and I still be and use it a lot!!! But, because there is often a but, it wasn't possible to use data visualization in graphic legends ... I remember there was a topic for beta-tester opened , where they spoke about that fonction (I cant see it because I'm not a beta-tester ) So whats new in 2024 ? thank you !!! Quote Link to comment
spettitt Posted December 15, 2023 Share Posted December 15, 2023 Data Vis in Graphic Legends should be like Viewports...where you select in the Shape Pane which Data Vis you do/do not want to apply to that Graphic Legend. Quote Link to comment
Ben3B Posted December 16, 2023 Author Share Posted December 16, 2023 On 12/15/2023 at 4:04 PM, spettitt said: Data Vis in Graphic Legends should be like Viewports...where you select in the Shape Pane which Data Vis you do/do not want to apply to that Graphic Legend. I wish it was like that, but it s not ... 😢 1 Quote Link to comment
Ben3B Posted December 18, 2023 Author Share Posted December 18, 2023 On 12/15/2023 at 4:04 PM, spettitt said: Data Vis in Graphic Legends should be like Viewports...where you select in the Shape Pane which Data Vis you do/do not want to apply to that Graphic Legend. or when you filter a graphic legend by viewport, the graphic legend should apply the same data vis as it is in the viewport it refers to ... Quote Link to comment
Pumpkin Posted December 31, 2023 Share Posted December 31, 2023 Hello ! For those who would like to vote for this more than justified request (Forum - Wishlist - Feature and Content Requests) : https://forum.vectorworks.net/index.php?/topic/106684-graphic-legends-to-be-able-to-interact-with-data-visualisation/ 1 Quote Link to comment
Fredrik Posted December 31, 2023 Share Posted December 31, 2023 Hello! I tried to extract the U-value for different Wall types in my Graphic Legend, but did not get it out. There is a value for R-value, but here in Norway we use U-value and this Field Name #R-Value# does not give out any value. Tried to work around by setting another Wall Type value to my U-Value, but did not find any that Graphic Legends could display. Could we have more options for displaying in our Graphic Legends? Quote Link to comment
Tom W. Posted December 31, 2023 Share Posted December 31, 2023 14 minutes ago, Fredrik said: Hello! I tried to extract the U-value for different Wall types in my Graphic Legend, but did not get it out. There is a value for R-value, but here in Norway we use U-value and this Field Name #R-Value# does not give out any value. Tried to work around by setting another Wall Type value to my U-Value, but did not find any that Graphic Legends could display. Could we have more options for displaying in our Graphic Legends? #WS_OBJUVALUE# will return the U-value. Quote Link to comment
Fredrik Posted December 31, 2023 Share Posted December 31, 2023 Thank You! Found also Acoustic rating #WS_OBJECTDATA('acoustic rating')# as Worksheet function and Fire Rating #WS_OBJECTDATA('fire rating')# Quote Link to comment
