  • 10
Graphic Legends to be able to interact with Data Visualisation
_James
1 answer to this question
44 minutes ago, _James said:
For us, we could then basically automate the way in which we identify differing wall styles on drawings. Currently this is just a regular viewport with all the colours added to the annotation space. The wall descriptions are then manually typed out. This introduces a lot of potential for errors, not to mention it being a tedious task.
In the meantime have you considered using Data Tags to label short lengths of Wall in a VP to create your legend instead? You could turn off the components so they resemble solid rectangles of colour then the Data Tag could return the 'Mark' + 'Description' fields of the Wall style (apply the Data Vis to the VP obviously to get the colours). Would cut out the manual/tedious element as the data would be coming from the Wall style. Although would mean drawing the lengths of Wall on a hidden design layer in order to generate the VP.
That's not to say I don't support your wish - have voted it up.
