Bruce Kieffer Posted December 1, 2023 Share Posted December 1, 2023 Is there a simple way to display the sheet layer title on a sheet? Quote Link to comment
Pat Stanford Posted December 1, 2023 Share Posted December 1, 2023 Use a Data Tag with a formula of #WS_LAYER# You can generate this from the Data Tag Worksheet functions - Layer. 4 Quote Link to comment
Tom W. Posted December 1, 2023 Share Posted December 1, 2023 #L# does the same. But I think I'm right to say you need an object on the sheet first to associate the tag with. Also, this returns the sheet number rather than the sheet title. #WS_'Title Block Sheet Data'.'Sheet Title'# will return the sheet title if you associate the tag with the title block (i.e. insert it using two points mode). Quote Link to comment
Pat Stanford Posted December 1, 2023 Share Posted December 1, 2023 No object required. The DT will pull the data directly from the Layer it is on. Not certain if the #L# option requires an object or not. If it is an Object Function then yes, it probably will require an object. #WS_Layer# absolutely does not require the DT to be associated. 2 Quote Link to comment
Tom W. Posted December 1, 2023 Share Posted December 1, 2023 1 hour ago, Pat Stanford said: No object required. You're absolutely right sorry! I was trying it out using 'Eligible Object Mode' when I should have been using 'Label Mode'... #L# works the same as #WS_Layer#. Similarly is there a way to return the sheet title without associating it with a TBB? Quote Link to comment
Pat Stanford Posted December 1, 2023 Share Posted December 1, 2023 2 minutes ago, Tom W. said: Similarly is there a way to return the sheet title without associating it with a TBB? General Functions Sheet Name - #SHEET# Sheet Number - #SHEETNUM# 2 1 Quote Link to comment
Tom W. Posted December 1, 2023 Share Posted December 1, 2023 2 minutes ago, Pat Stanford said: General Functions Sheet Name - #SHEET# Sheet Number - #SHEETNUM# Thank you! (Good to know there's three different ways to return the sheet number!) Quote Link to comment
Bruce Kieffer Posted December 1, 2023 Author Share Posted December 1, 2023 14 hours ago, Pat Stanford said: You can generate this from the Data Tag Worksheet functions - Layer. I need help with this. I have not used data tags before. Quote Link to comment
rDesign Posted December 1, 2023 Share Posted December 1, 2023 30 minutes ago, Bruce Kieffer said: I need help with this. I have not used data tags before. Take a look at this course available at Vw University: Vw Univ : Data Tag Tool If you are Service Select member there is another one in the Coffee Break series on Custom Data Tags. Or take a look at the Help File page on Data Tags: Vw 2024 Help File : Adding Data Tags and Labels Quote Link to comment
Pat Stanford Posted December 1, 2023 Share Posted December 1, 2023 VWU is best option. Here is the really short version. Not even good enough to be given the "Super Short" tag. 😉 Data Tag of Sheet Name.vwx Quote Link to comment
Bruce Kieffer Posted December 2, 2023 Author Share Posted December 2, 2023 @Pat Stanford, Thanks. I got it working. I will watch the movies. I may need to ask for a bit more explanation after watching. Quote Link to comment
