Bruce Kieffer Posted October 31, 2023 Share Posted October 31, 2023 Is there a way to make a Custom Dimension Standard as a resource? Two workarounds I've use so far are copy/paste the dimension formatted with my custom standard from one drawing to another. That brings the dimension standard to the other file. The other workaround is to draw dimensions in one of my library drawings and apply my custom dimension standards to each and then use that drawing as the source to import my custom dimension standards to another drawing. These workarounds seem counter intuitive to the purpose of the resource manager. I want to save my custom dimension standards in the resource manager. Is there a good way to do that? Quote Link to comment
Pat Stanford Posted October 31, 2023 Share Posted October 31, 2023 Short answer: No. Dimension Standards are not Resources. Longer answer: Your workarounds are probably the best options right now. Other than making sure your Dim Std. is stored in your template file(s) and always starting a drawing from a template. 1 Quote Link to comment
markdd Posted October 31, 2023 Share Posted October 31, 2023 (edited) I convert a Dimension with a Custom Standard to a Symbol. Just importing the Symbol into a new file as a Resource will import the Dimension Standard as well. It would be much more consistent if Dimension Standards were shareable resources though. Edited October 31, 2023 by markdd 2 Quote Link to comment
Bruce Kieffer Posted October 31, 2023 Author Share Posted October 31, 2023 3 minutes ago, markdd said: I convert a Dimension with a Custom Standard to a Symbol. Just importing the Symbol into a new file as a Resource will import the Dimension Standard as well. It would be much more consistent if Dimension Standards were shareable resources though. That's a good idea. I will give it a try. Thanks. Quote Link to comment
line-weight Posted October 31, 2023 Share Posted October 31, 2023 my current approach included here https://forum.vectorworks.net/index.php?/topic/107432-make-achieving-graphic-consistency-on-sheets-less-painful/#comment-467621 Quote Link to comment
