Geoimage: Incorrect scale
Uhm, it makes me always nervous when I look at Airport closeups and
see crossing runways or even taxiways crossing runways.
Like Zurich Airport in Switzerland.
Yours is a quite mild example, but still ... they could meet if things happen.
Unfortunately no clue about your scaling problem as I am a georeference
novice and do not know how to officially dimension a runway.
I personally am not used to which georef system I have to choose from.
So I realize that often the coordinates I read out of web maps will lead
to an offset of the site in VW which I think is also a scaling/georef distortion
standard thing.
Once I got the correct position of my site, the Geoimage looked reasonable
in scale ....
But not sure if that has anything to do with your case.
1 minute ago, Tom W. said:
It looks scaled-up to me. Is the problem the georeferencing i.e. you're using the wrong EPSG code? I don't think 3857 is correct for Ireland so you could be suffering all sorts of distortion as a result. In GB I use EPSG 27700
Thanks Tom, I was hoping it was something like this. I'll look in that direction and revert.
Basically what I tried to say 🙂
  • 3 weeks later...
@bcd did switching CRS to 27700 work? I think one needs to accept the transformation option when switching.
If nothing else works, images, incl geotiffs, can be conformed (scale, rotate, stretch) in QGIS by locating a few known ground control points. This is in the Georeferencer tool. I think one of the polynomial transformation algorithms does the rubber sheet stretch.
-B
Last time:
Thank you @Tom W. & @zoomer. This is the correct answer:  ESPG: 2157 -IRENET95 / Irish Transverse Mercator
Luckily, in this case, the difference between the default and the site was significant - pointing up the error and the importance of setting the correct coordinate system.
I originally searched for 'Ireland' and didn't get any results. This would be a helpful VW improvement to tag the country along with the name of its coordinate system/s so that searches are more reliable.
1 minute ago, bcd said:
image.thumb.png.4b345ad41c70bc2d35972534b8e1e2f7.png.5f9f99209a472fb105e04c5516e85848.png
Yep EPSG 29902 is there too as suggested earlier. I'd be interested to know whether there's any discernible difference (distortion) between these different projections. Plus 27700 which is what I use for the UK + which includes most of Ireland.
I understand EPSG 29902 TM65 was replaced by EPSG 29903 TM 75 by EPSG 2157 IRENET95
The question I guess is which one agrees with the transformation that the Arcgis is using for the satellite imagery.
I'll run a comparison of the various coordinate systems you mention. I have a feeling that the differences between them, while real, will not be discernible with the satellite imagery that we're getting.
