When using the push pull tool in VW 2023, when there are two faces of two different objects overlapping, so on the same 2D plane. The push pull tool only highlights the largest of the two faces and i cant select the smaller one to push pull. I will use a photo for an example. This box section end (yellow square) i cannot select to extrude (push/pull) as it is flush with the larger edge of the box section (highlighted red).
Is there a way to select the yellow bit of box section without moving the larger red piece?
oliver.williams
Hello,
Many Thanks,
5 answers to this question
