Kevin K Posted May 28, 2023 Share Posted May 28, 2023 @Stephan Moenninghoff I have two InteriorCad inquiries pertaining to the screenshot below: 1) I don't believe there is an option in InteriorCad xs to address bypass sliding cabinet doors? I created the two doors by using 'custom parts'. Is there another way? 2) With the two custom parts doors and the two holes used as 'pulls' in the doors, created with the 'drilling' option......, if I elect to say make the cabinet 12" wider, the custom parts items don't move in concert with the new overall cabinet width. Is there an option to allow for this? Thanks -Mr. Greek Salad 🙂 1 Quote Link to comment
Kevin K Posted May 28, 2023 Author Share Posted May 28, 2023 Tom I thought you may have noticed my post. I was surprised when making the cabinet wider that those items did not center themselves to align with the new cabinet width. Perhaps @Stephan Moenninghoff will shed some light on the issue 🙂 Quote Link to comment
Blinkglitter Posted May 30, 2023 Share Posted May 30, 2023 @Kevin K This is possible with the box objects feature, under 'objects' in the cabinet settings. I'm not sure if this is available is Interiorcad XS. 1 Quote Link to comment
Kevin K Posted May 30, 2023 Author Share Posted May 30, 2023 @Blinkglitter Thanks for the reply....I guess Stephan is on holiday 🙂 When you say it is possible using the box object (if in fact it IS available for xs, it will make sliding bypass doors, along with the drilling objects maintaining their aspect ratios as well, when increasing the width of the cabinet?? You were a bit vague. I could upload the file and let you have a go, but if you do not have the XS version installed, it would do you no good. I will investigate this shortly and thanks again for the response 🙂 -Kev 1 Quote Link to comment
Blinkglitter Posted May 31, 2023 Share Posted May 31, 2023 @Kevin K That's OK, Stephan probably gets asked a lot of questions. I would make the doors as usual inset doors, one inset more than the other. This will give the appearance of sliding doors. You can then have a drilling as a box object that will move in relation to 'box' containing the door if you increase the width or height of the cabinet. If you upload the file I will make a video showing you how to do it. I have the full version, I haven't tried opening an XS version but can give it a go. Hope that helps 1 Quote Link to comment
Kevin K Posted May 31, 2023 Author Share Posted May 31, 2023 Thanks for that. What you mentioned works, but, you need to also tweak the 'reveal' on each door to get them to overlap... Still not understanding your 'box object' comment.. Here is a basic 2022 file if you want to demonstrate 🙂 CAB TEST.vwx 1 Quote Link to comment
Blinkglitter Posted May 31, 2023 Share Posted May 31, 2023 15 minutes ago, Kevin K said: Thanks for that. What you mentioned works, but, you need to also tweak the 'reveal' on each door to get them to overlap... Still not understanding your 'box object' comment.. Here is a basic 2022 file if you want to demonstrate 🙂 CAB TEST.vwx thanks I will have a look and show you Re tweaking the reveals, you can save the door arrangement as a ‘set’ and call it ‘double sliding doors’ that way you have a template for the future 2 Quote Link to comment
Kevin K Posted June 1, 2023 Author Share Posted June 1, 2023 @Blinkglitter You must be making quite the movie 🙂 Honestly, I am quite intrigued as to how you will convert a 3d drilling object into a 'box' object. I have been studying this situation a bit and no flashing lights have gone off in my brain yet as to facilitating this. You may not need to take the time to make a movie, but just give me an exact explanation, step by step? Thanks again for taking the time to address this. I await your sage advice 🙂 Quote Link to comment
Tom W. Posted June 1, 2023 Share Posted June 1, 2023 @Kevin K behold: The circular finger pull was inserted as a Box Object. I turned a Drilling 3D into a symbol. Obviously the placement leaves a little bit to be desired but that's the principle at least Quote Link to comment
Tom W. Posted June 1, 2023 Share Posted June 1, 2023 Ok now I have two of them in the right place: Cabinet resized: Just don't open the doors 🙂 Quote Link to comment
Kevin K Posted June 1, 2023 Author Share Posted June 1, 2023 Tom hahahaha...yeah..beware door openings 🙂 That is very hopeful!! Good work...I bet there is a way to facilitate this without the floating extrusions...? Quote Link to comment
Tom W. Posted June 1, 2023 Share Posted June 1, 2023 Just now, Kevin K said: I bet there is a way to facilitate this without the floating extrusions...? Perhaps but the object (symbol) is bound to the cabinet rather than the doors so perhaps not... Quote Link to comment
Kevin K Posted June 1, 2023 Author Share Posted June 1, 2023 So....the goal and trick is to get it bound to the door. Anyway, good progress !! Quote Link to comment
Blinkglitter Posted June 2, 2023 Share Posted June 2, 2023 You won't be able to bind it to the door. Tom seems to have saved me the job? Sorry Kevin was at a wedding yesterday and also in the UK so timezones... Quote Link to comment
Kevin K Posted June 2, 2023 Author Share Posted June 2, 2023 @Blinkglitter No worries....Weddings are important 🙂 Well, as Tom has noted, it isn't really a perfect solution. But, thanks for your efforts 🙂 Quote Link to comment
E|FA Posted June 2, 2023 Share Posted June 2, 2023 Way above my pay grade, but could you create a handle symbol that only has the drilling (no actual handle), and make the hole the size you want? 1 Quote Link to comment
Kevin K Posted June 2, 2023 Author Share Posted June 2, 2023 @E|FA you can do that. One way is to duplicate the handle symbol and remove the portions other than the drilled holes... Note the screenshot. The center drawer has no handle, just the drilled holes. Quote Link to comment
Tom W. Posted June 2, 2023 Share Posted June 2, 2023 2 hours ago, Blinkglitter said: You won't be able to bind it to the door. Tom seems to have saved me the job? Sorry Kevin was at a wedding yesterday and also in the UK so timezones... Nevertheless it's got to be a good trick to have up your sleeve so thanks for suggesting it @Blinkglitter Presumably another way to do it would be to have the finger pull drilling as a handle symbol with no handle geometry, as per @Kevin K's post above...? Something else for me to try... Quote Link to comment
Kevin K Posted June 2, 2023 Author Share Posted June 2, 2023 Oooooooohhhh….now that is a thought! Quote Link to comment
E|FA Posted June 2, 2023 Share Posted June 2, 2023 47 minutes ago, Tom W. said: Presumably another way to do it would be to have the finger pull drilling as a handle symbol with no handle geometry, as per @Kevin K's post above...? Something else for me to try... That's what I meant. Thanks for explaining it better. 1 Quote Link to comment
Tom W. Posted June 2, 2023 Share Posted June 2, 2023 13 minutes ago, E|FA said: That's what I meant. Thanks for explaining it better. @E|FA apologies there are so many interiorcad posts flying back + forth I lost track of which thread was which + didn't put two + two together! All credit to you for the idea: I am going to try it now... Thank you! 1 Quote Link to comment
Tom W. Posted June 2, 2023 Share Posted June 2, 2023 Drilling 3D as a handle works great @E|FA for side-hung doors: But I couldn't get it to work for the sliding doors as per the original post because I couldn't get the handles bound to the outer edge of the doors... (which is where they need to be when you resize it). But all good fun... 1 Quote Link to comment
Tom W. Posted June 3, 2023 Share Posted June 3, 2023 9 hours ago, Tom W. said: But I couldn't get it to work for the sliding doors as per the original post because I couldn't get the handles bound to the outer edge of the doors... (which is where they need to be when you resize it). @Kevin K has got it to work! So @E|FA's hole-handle method is definitely the way to go! Quote Link to comment
